Hardware Discovery - Pontiac GTO Forum
 2Likes
  • 2 Post By Noangelbuddy
post #1 of 3 (permalink) Old 04-01-2018, 08:56 AM Thread Starter
Quoted: 12 Post(s)
Hardware Discovery
Most of my control arm bolts were in very good shape so I was thinking about reusing them. I damaged one and went to a local auto parts store seeking a replacement, they did not have,or stock, what I thought was fairly generic hardware. I discovered a wealth of grade 8 zinc and steel hardware at Tractor Supply. Instead of buying sets of 4,6, or 8 bolts from a catalogue. I get it immediately and for less from Tractor Supply where they sell it by the pound.
In addition, I saw techniques to Zinc plate steel hardware and was going down that path until I found out about Tractor Supply. Only downside to the bolts is that they are not tapered at the end, which was not an issue for the control arms. It was an issue for the motor mounts though, where I reused the old bolts.
NoAngelBuddy
deanhickey and cij911 like this.
Noangelbuddy is offline
post #2 of 3 (permalink) Old 04-02-2018, 10:12 PM
Quoted: 11 Post(s)
I sometimes go to my local Lowes. In their hardware supply section, you'll find grade 3 and grade 8. They will be plated bright zinc for the grade 3 and zinc chromate (yellow/gold)for the grade 8.
Sixty7GTO is offline
post #3 of 3 (permalink) Old 04-03-2018, 04:27 AM
GTOJUNIOR's Avatar
Quoted: 66 Post(s)
TSC is good as well as Fastenal, at least our local one is. Worth a look if you have one nearby.
Our Lowes had a great Hardware selection but recently have fell off on keeping it stocked.
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
Hardware Source MAP53 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 0 07-12-2015 05:55 AM
hood hardware on a 65 Anthony.cameron 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 08-07-2013 01:04 PM
Unfortunate Frame Discovery During Resto FB68 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 13 05-09-2011 06:15 AM
