Help with "Street" Posi and Gear - Pontiac GTO Forum
post #1 of 2 (permalink) Old 03-21-2018, 09:47 AM Thread Starter
Hello - First time post. I have a 1967 LeMans that has been a drag car since the mid 80's. I want to make a prostreet car out of it so I am making the transition. It currently has a Dana 60 with a spool and 4:88 pro gear. It seems like there are many options for a posi rear end and I don't know where to start. Here are the specs on the car - 1967 LeMans, 502" BBC (600ish hp), TH400, Narrowed Dana 60, 31X16.5 M/T tires. I would appreciate any suggestions for a posi carrier for my Dana 60. Also, suggestions for a gear would be great too. This will be a car that mostly goes to shows with the occasional 1/8mi full throttle release of aggression . Thank you.
67LeMonster is offline
post #2 of 2 (permalink) Old 03-21-2018, 03:06 PM
Dana60 application Eaton True-Trac, part #915A385 fits 4.10 & numerically lower gears (3.54's)
your Dana60 axles should be 35 spline, I have no idea what style of outer axle bearing/retention when your rear was constructed.
Personally, in other than putt around street builds, I prefer large diam tapered bearing axle retention, either A10 or A20 tapered axle bearings/hsg ends.
"OLD TIMER" Street Racin' PontiacJim Racing and Kill Forum 24 08-30-2015 06:56 PM
Searching for "Street is Neat" ScarabGT 1964-1974 Tempest, Lemans & GTO General Discussion 8 10-01-2009 12:23 PM
Any "organized street races" in the N. Cali Monsterman Racing and Kill Forum 0 10-18-2006 12:02 PM
"Top Gear" Richard Hammond Injured MaximumPwr The Lounge 3 09-21-2006 11:54 AM
