How much frame and body movement is ok? - Pontiac GTO Forum
post #1 of 6 (permalink) Old 10-16-2013, 09:05 AM Thread Starter
I have a 67 GTO convertible. It's my first convertible and I know they are known for body flex but I just wanted some opinions on this. I've had the car on jack stands for various projects the last few months and I've noticed a lot of movement in some cases.
I'd say the worst case is when I would put my jack under the rearmost section of the frame right in front of the wheel well. When I lift both sides evenly there are no issues but if it's only one side then the body flexes so much it increases the gap on the rear of the door more than 1/4 inch or so.
Is this much flex normal or do I have some serious issue?
WhittP is offline
post #2 of 6 (permalink) Old 10-16-2013, 09:58 AM
chuckha62's Avatar
Quoted: 18 Post(s)
It doesn't sound too abnormal at all. Even the hardtops and coupes flex a little when you jack up one corner. My '67 post coupe (arguably the stiffest body style) flexes some if I jack up one corner. The convertible has to flex more than that! My '69 Corvette convertible flexed to the point you couldn't open the door, yet the car was solid as a rock on the road without a squeak or rattle anywhere.
chuckha62 is offline
post #3 of 6 (permalink) Old 10-16-2013, 10:44 AM
Is your frame boxed?
post #4 of 6 (permalink) Old 10-16-2013, 10:51 AM Thread Starter
Yes, I assume it's the standard boxed convertible frame. It looks like it's in good shape but it's hard to tell what's inside the areas I can't see.
WhittP is offline
post #5 of 6 (permalink) Old 10-16-2013, 01:04 PM
Quoted: 119 Post(s)
I have a '67 GTO convertible and have had it 30 years. It flexes enough so that you don't want to open/close the doors when it's on a lift. Totally normal. Note that the convertibles have screw on rub pads at the upper door openings for just this reason. No worries. If you want flex, try driving a newer Firebird/Camaro or Mustang convertible. Terrible.
post #6 of 6 (permalink) Old 10-16-2013, 02:27 PM Thread Starter
Thanks for putting me at ease. I guess it's pretty normal.
WhittP is offline
Body off frame question Wmkcchwhite 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 16 07-29-2011 02:33 PM
68-72 A-Body Frame Questions TK69tempest 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 7 04-02-2011 01:51 AM
67 lemans body and frame bobby326 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 4 07-09-2010 01:18 PM
Body off frame question. Josh.AZ.GTO 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 1 09-22-2009 06:39 AM
