Id rear end gears in a 65 GTO - Pontiac GTO Forum
post #1 of 2 (permalink) Old 08-23-2017, 05:00 PM Thread Starter
finally took cover off rear end to ID what is in there. Looks like Richmond 82-0550-1. 39 teeth on large gear and 11 on small one. not sure what I have. I have not driven this car. To many projects with it. Its a 4 speed car presently with a 455 tri power. will be changing that engine out for a 428 which is presently at rebuild.
what are these gears? will they suffice for a week end cruiser? Thanks.
army6741 is offline
post #2 of 2 (permalink) Old 08-23-2017, 05:04 PM
Quoted: 79 Post(s)
3.55 gear ratio. I would leave it in for now and see how you like it once the car is drivable again.
Sent from my XT1585 using Tapatalk
Shake-N-Bake is offline
New Rear end gears sknight751 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 6 05-12-2009 07:48 PM
Rear end gears woffman5 Drive train, suspension, alignment and brakes. 3 09-27-2006 07:03 PM
rear end gears wannagofast 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 3 09-23-2006 08:07 AM
Rear End Gears smyles Drive train, suspension, alignment and brakes. 5 07-30-2006 09:41 PM
Rear End Gears Wing_Nut Service, Maintenance and Technical Discussion 3 04-25-2005 08:41 PM
