interchange of '66 and '67 rear ends? - Pontiac GTO Forum
post #1 of 1 (permalink) Old 08-29-2018, 09:03 PM Thread Starter
Quoted: 5 Post(s)
I need some advice on the above, I seem to always get conflicting opinions... I have a '67 GTO and I want to put a '66 rear end in it. The question is about the coil spring set-up... can I use '66 springs with the retainer plates? Can I just use '67 springs? Can either of the year's springs be cut to make the swap work? Any suggestions on the best way to get the job done would be appreciated. I've already got the '66 rear ready to go in (long story $$) so I don't want to give up and seek out a '67 rear at this late stage. I'm not bothered by the 1" narrower, just the coil situation. Thanks.
JimmyF is offline
67 dual gate interchange? wishihaditback 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 06-09-2011 09:25 PM
what parts interchange between 66-67? busaben 1964-1974 Tempest, Lemans & GTO General Discussion 8 05-14-2011 11:04 PM
67 interchange buzz1670 1964-1974 Tempest, Lemans & GTO General Discussion 2 04-25-2010 11:43 PM
Durability of rear ends chad1140 Racing and Kill Forum 2 04-09-2005 02:49 PM
How tough are the rear ends in these Goats?? tiresmoker Service, Maintenance and Technical Discussion 4 02-25-2005 05:50 PM
