Issues removing my filler bolt on my muncie - Pontiac GTO Forum
post #1 of 8 (permalink) Old 08-19-2018, 03:21 PM Thread Starter
frankie68's Avatar
Quoted: 6 Post(s)
Hello. I'm having issues removing the filler bolt on my muncie. Trans is in the car and no oil in it right now. I've been trying to remove it but its stripped so badly that soon there'll be nothing left of it.
Any suggestions aside from pulling the trans and tapping it out.
Wondered if I'd be able to simply remove the speedo cable and fill it from there. Both the speedo hole and filler hole appear to be fairly level to one another.
Any thoughts? Wondering if it's even doable
frankie68 is offline
post #2 of 8 (permalink) Old 08-23-2018, 06:55 PM Thread Starter
frankie68's Avatar
Quoted: 6 Post(s)
post #3 of 8 (permalink) Old 08-23-2018, 07:39 PM
Quoted: 391 Post(s)
Originally Posted by frankie68 View Post
I would not try to scrape by and do a half baked fix. Pull the trans and take it to a trans shop who has probably encountered the same situation and may know how to remove it without damage to the case. Sometimes machine shop/engine builders have tricks to remove stubborn plugs which are found in an engine.
post #4 of 8 (permalink) Old 08-28-2018, 08:39 PM Thread Starter
frankie68's Avatar
Quoted: 6 Post(s)
Appreciate the response, however my question wasnt answered.
If anyone has some transmission knowledge and could advise me if I could fill the trans through the speedo hole, id appreciate it.
Really just wondering if adding oil in the speedo hole, if the oil goes to the same place
post #5 of 8 (permalink) Old 08-28-2018, 09:20 PM
Quoted: 391 Post(s)
Never did it that way. Don't know anyone else who has done it that way. It seems like it would work in a pinch and you would just add the correct number of pints of gear oil, but I would email one of the many Muncie trans rebuilders with that question just to be on the safe side.
post #6 of 8 (permalink) Old 08-28-2018, 09:25 PM
Quoted: 8 Post(s)
I just went through this exact scenario, I can't answer your question about filling through the speedo hole. But I can tell you how I got mine to free up. I used a little bottle torch and went around the outside on the aluminum for several minutes. Then I clamped down on it as tight as I could with a set of vise grips. Just pushing by hand wouldn't free it. But then I had the idea to give the pliers a few short blows with a 2' 2x4 held with one hand on each end. It suddenly started to move, after the first movement it turned easy. I believe the short quick blows acted like an impact wrench and jarred it free. Good luck I know just how you feel.
Rob
1966GT0 is offline
post #7 of 8 (permalink) Old 08-29-2018, 07:30 AM
Quoted: 155 Post(s)
^^ If the bolt is too deformed to use the proper tool (4 sided socket), then I would use really good vice grips or adjustable wrench that locks....try tightening first to break the seal and then loosen. Obviously replace the plug with a new one.
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is online now
post #8 of 8 (permalink) Old 08-29-2018, 10:35 PM Thread Starter
frankie68's Avatar
Quoted: 6 Post(s)
Awsome
I'll make sure I try the suggestions. Much appreciated
1964 12 bolt to 10 bolt remy30006 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 10 08-06-2013 10:53 PM
Is the 10 Bolt 8.2 BOP Carrier the same as Chevy 10 Bolt? mighty454 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 6 04-21-2010 03:30 PM
10 Bolt Versus 12 Bolt Rear Axle take5 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 10 09-28-2009 03:45 PM
69 GTO 10 bolt non-posi convert to 12 bolt posi AzStateFan 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 0 09-12-2009 04:34 PM
2 bolt vs. 4 bolt baja 1964-1974 Tempest, Lemans & GTO General Discussion 1 07-06-2005 12:33 PM
