Limited slip or not? - Pontiac GTO Forum
post #1 of 13 (permalink) Old 10-03-2015, 02:02 PM Thread Starter
Just bought a restored '64 with a .030 over 455/tri-power. I was told that it has a non-posi rear, so I wanted to verify. I raised the rear tires and spun one of them to see what the other one did, and it did not turn at all. Same result when I spun the other tire. It took more effort than I thought to spin each wheel, & the drive shaft turned both times. My knowledge is that with an open rear, other tire should spin opposite, and with a posi rear it should spin the same direction. What may be going on here?
Thanks for any guidance.
vev46 is offline
post #2 of 13 (permalink) Old 10-03-2015, 04:10 PM
Quoted: 404 Post(s)
It's not a posi. Nothing going on.
post #3 of 13 (permalink) Old 10-03-2015, 08:50 PM
The driveshaft spinning is the question; was the transmission in gear (manual transmission) or park (automatic)?
younggto is offline
post #4 of 13 (permalink) Old 10-04-2015, 05:12 PM Thread Starter
4-speed muncie, in neutral
vev46 is offline
post #5 of 13 (permalink) Old 10-05-2015, 07:41 AM
The transmission needs to be in gear to check for posi vs open rear.
younggto is offline
post #6 of 13 (permalink) Old 10-05-2015, 01:33 PM
Quoted: 16 Post(s)
Uhh, no.
post #7 of 13 (permalink) Old 10-05-2015, 01:39 PM
HP11's Avatar
Quoted: 24 Post(s)
If you think about that statement you'll understand why it's wrong. With an automatic, it does nothing, with a stick you're turning the drive shaft, transmission, clutch and, therefore, the engine.......
HP11 is online now
post #8 of 13 (permalink) Old 10-05-2015, 02:58 PM
Quoted: 106 Post(s)
I thought about swapping my pegleg out with a posi but the more I thought about it I decided to just keep it original.
I don't plan on drag racing the car and since I live in the mountains and drive these roads drifting or swapping ends isn't something I need to do.
Think about how you plan on driving the car before you spend the money to change it out.
Goat Roper is offline
post #9 of 13 (permalink) Old 10-06-2015, 01:47 PM
One tire in the grass the other on the road, do a small burnout both tires will spin if it's a limited slip. If it's open just the one in the grass will spin. You could always do an Auburn posi unit, my limited slip one went out so I put one in mine years ago and never looked back.
http://www.auburngear.com/
post #10 of 13 (permalink) Old 10-06-2015, 11:57 PM
I have always liked 2 black lines ,myself.
Irishmic is offline
Limited slip FlambeauHO 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 20 03-22-2012 10:08 AM
limited slip problems? Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 1 07-07-2011 09:22 PM
Limited Slip and No Slip Differentials....Whats the difference? xconcepts 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 06-16-2011 08:18 AM
limited slip diff. vanillagorila Drive train, suspension, alignment and brakes. 0 09-12-2006 06:57 PM
