looking to upgrade tranny - Pontiac GTO Forum
post #1 of 3 (permalink) Old 04-26-2018, 08:55 AM Thread Starter
Good morning gentlemen , new to the forum. I have a 1967 pontiac tempest matching number 326 engine 2 speed st300 tranny. looking to rebuild the tranny , does anyone know if i’m able to put in a third gear or put in better gears ? the tranny runs fine , just looking to upgrade the tranny but keep the matching numbers. any suggestions ?
mhyl2000 is offline
post #2 of 3 (permalink) Old 04-26-2018, 11:50 AM
1968gto421's Avatar
Quoted: 72 Post(s)
To my knowledge the easiest swap is to put in a BOP TurboHydromatic 350, AKA TH350. Using a TH350 with the BOP bellhousing (not Chevy) should be a bolt in swap. Hopefully some of the members here who have done this will chime in with tips. Below are some links to help:
https://www.gtoforum.com/f50/67-leman...e-th350-28113/
This is similar to the tranny in your Tempest and the chassis is common to GM A-bodies.
1968gto421 is offline
post #3 of 3 (permalink) Old 04-26-2018, 05:25 PM Thread Starter
ok thanks for the info i will start to look for a th350 with a bop bell housing .
mhyl2000 is offline
66 Tranny chieftugger 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 3 04-30-2017 06:29 PM
Need advice converting an Turbo 400 auto tranny to a manual tranny jimmy328 1964-1974 Tempest, Lemans & GTO General Discussion 2 09-16-2012 04:35 PM
Tranny upgrade on my '67... jeffdetrick Drive train, suspension, alignment and brakes. 0 01-15-2007 09:47 PM
pontiac tranny to chevy tranny wannagofast 1964-1974 Tempest, Lemans & GTO General Discussion 1 03-27-2006 08:23 AM
