M-21 Overdrive Gearset - Pontiac GTO Forum
post #1 of 2 (permalink) Old 05-03-2017, 03:19 PM Thread Starter
Couple years back there were gearsets that gave the M-21 an overdrive. Basically 3rd gear became the overdrive and then you flipped the shift lever and basically swapped the shift pattern between 3rd and 4th. these still available? anyone have any experience with them?
Brad3112 is offline
post #2 of 2 (permalink) Old 05-03-2017, 05:23 PM
Quoted: 390 Post(s)
Sounds like a trucker tale to me, that's what you do with a 9 or 13-speed - flip the top gear which makes for a reversed gear pattern. Takes a while to get used to the "U-pattern" vs the typical "H-pattern" shifting.
For the Muncie, Beaver Brook offers the gear cluster to do this, $795.00. They still show it in their catalog: Beaver Brook - Muncie Transmission Parts
From what I have read about them when they first came out, you basically are turning your transmission into a 3-speed with OD.
Gear Vendors Overdrive 65gto 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 6 03-02-2016 05:36 AM
Cheap overdrive swap? Orion88 1964-1974 Tempest, Lemans & GTO General Discussion 4 01-14-2014 08:59 PM
Cheapest way to get overdrive xconcepts 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 68 08-31-2010 03:19 PM
overdrive danthepontiacman 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 04-22-2010 01:50 PM
Automakers in overdrive 05GTO In the News 0 01-07-2005 04:56 AM
