M20 transmission - Pontiac GTO Forum
 1Likes
post #1 of 12 (permalink) Old 10-20-2019, 08:06 PM Thread Starter
M20 transmission
hi all Rob hear great site im doing a frame off restoration of a 1968 gto what i would like to know is if the m22 is original to the car the case number is 3925660 P8R03, tailshaft number 3857584 input shaft has 10 spline 2 rings output shaft has 26 side cover number is 3884685 ok the car was made in november 3 week it has a posi rear end with 355 gears i hope this is enough info thanks all
simpleman101 is online now
post #2 of 12 (permalink) Old 10-20-2019, 10:43 PM
BLK69JUDGE's Avatar
Quoted: 67 Post(s)
whats the vin # stamped ........ ?? on the tranny .........
m-20 with 2 rings
R is october .... kinda late for a 68
studs holding the levers on or bolts into the case holding the shift levers...
kinda doesnt matter but Im curious
Scott
BLK69JUDGE is online now
post #3 of 12 (permalink) Old 10-21-2019, 07:18 AM
Quoted: 392 Post(s)
You should have a partial VIN number stamped on the transmission that matches the engine VIN.
Here is a pretty good site that may help. It is aimed at the Chevelle, but will still give you all the info you need: https://www.chevellestuff.net/qd/muncie.htm
post #4 of 12 (permalink) Old 10-21-2019, 10:04 AM Thread Starter
m2o transmission
good article took the wire wheel to the case no partial vin any wear not even any grind marks wear someone would of removed them on the side cover it has studs and nuts to hold linkage on but the tail housing has a bolt that holds the linkage on thanks all
post #5 of 12 (permalink) Old 10-21-2019, 02:36 PM
BLK69JUDGE's Avatar
Quoted: 67 Post(s)
major clue there
69 azz end .......69 case ... 68 side cover or shifter forks n hardware from the original tranny
the partial vin will /should be .. within a couple inches of the date stamp
smaller than the date stamp .. and closer to the mid plate ////
or
on top facing the floor of the car ... right against the bell housing...
I have seen some early ones vin stamped on the machined surface the side cover bolts to
ON THE case .... there a little pad that hangs out next to the gasket...where the date is on this one..
so with the 69 tail shaft and lever that makes it a little tough t o get the back up
lite switch to work.....68 only style,,,,
Scott
ID:	121893   Click image for larger version
ID:	121895   Click image for larger version
post #6 of 12 (permalink) Old Yesterday, 10:20 AM Thread Starter
i see the back up light will be a problem my shiftier dose not have that hole did 1968 gto come with a neutral safety switch this car was raced a little by my brother in vary early 80's its been off the road since 77 this is a frame off restoration i.m doing the frame is painted i.m in the process of putting a complete floor with rockers in so many spot welds thanks
post #7 of 12 (permalink) Old Yesterday, 12:40 PM
Quoted: 392 Post(s)
If original, and not a 4-speed conversion, the trans had a back-up switch fitted to it. You should still have the wiring somewhere in sight? There are different styles.
I believe Ames may have it. Hurst sells a bracket/switch that will work. Ebay seems to have a few types, and there are universal set-up that can be fitted. You want to make sure you have all the matching components for each style of switch. The Hurst looks to be the simplest to install/use.
post #8 of 12 (permalink) Old Yesterday, 03:30 PM
Quoted: 119 Post(s)
He has the bellcrank for the switch on his reverse selector arm in the pic....the rod and the switch are gone, though.
post #9 of 12 (permalink) Old Yesterday, 04:47 PM Thread Starter
great guys making progress went thru boxes of parts found the original 68 shifter with back up light switch and wire harness now the problem i have is the neutral safety switch does anyone have pic of how it mounts and maybe parts list this is for a 68 thanks Rob
post #10 of 12 (permalink) Old Yesterday, 06:10 PM
Quoted: 392 Post(s)
Don't believe there is a neutral safety switch - that's for automatics. I think the neutral safety switch is when the trans is in neutral or you push in your clutch pedal in case you left it in gear. That's what I'm thinking, but I could be wrong.
simpleman101 likes this.
Currently Active Users Viewing This Thread: 8 (1 members and 7 guests)
BLK69JUDGE
