Muncie 4 speed Drive gear removal - Pontiac GTO Forum
post #1 of 2 (permalink) Old 02-10-2016, 05:30 PM Thread Starter
Layzdude's Avatar
Is there a way to do this without pulling the main trans shaft off? I may need to replace the reverse gears and need to get the drive gear off. I know it is pressed on.
Name:	2016-02-10 15.44.09.jpg
Layzdude is offline
post #2 of 2 (permalink) Old 02-13-2016, 11:06 AM Thread Starter
Layzdude's Avatar
Was able to get it off. Not as hard as I thought.
Posted in this thread.
https://www.gtoforum.com/f122/muncie-...ad-bad-101114/
Layzdude is offline
Speedometer Drive Gear and Driven GEAR timmyg 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 05-05-2012 04:48 PM
Muncie speedometer gear SPCMarty 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 13 04-08-2012 08:03 PM
Gear oil for a 4 speed muncie 1968 Q8 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 10 06-19-2011 12:56 AM
What type of Gear Oil - '68 Muncie 4 speed 1968 Q8 Drive train, suspension, alignment and brakes. 1 06-08-2011 09:29 PM
66 gto muncie 4 speed vibration / rattle in shifter "at speed" take5 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 11 10-28-2010 08:43 PM
