MY6 4 Speed OD Conversion - Pontiac GTO Forum
post #1 of 3 (permalink) Old 03-14-2019, 11:23 AM Thread Starter
dcoydad's Avatar
Quoted: 6 Post(s)
Hi folks. My 68 is numbers matching, my plan is to shelf the entire drivetrain and replace with daily driver stuff so I'm not worried about tearing up some history. So I started with a factory open rear end geared around 3:23 but hated the one tire fire. I stumbled onto a nodular posi out of a 69 Judge with 3:90s. Fixed the fire but killed the road cruise. Now taching around 4000rpm at 75 on the interstate. I've been looking at options: ruled out the Tremek/TKO because I don't want to modify my floor pan. Considering the new Mcleod 5speed because its advertised as a direct drop in without modifications - but it is expensive... Ran across on old timer who mentioned a possibility and wanted to ask the forums for advice.
Has anyone converted the MY6, 4 speed, OD tranny's from the chevy/gm trucks into their goats? My understanding is the OD 4th gear runs at .74 which is way better than the 1 to 1 on my Muncie. The dimensions look very good too. I understand the tranny is actually a version of the Chrysler A833 and pretty darn tough. Another question is? Do they make conversion plates for the A833 to a BOP bellhousing? The MY6 has been hard to find and I'm still looking --- so if you have one sitting around? The A833s are out there if there is an adapter plate available... Anyone been there done that? Let me know. Thanks
dcoydad is offline
post #2 of 3 (permalink) Old 03-14-2019, 08:58 PM
Quoted: 401 Post(s)
I don't think I would do it after reading this thread. This is for a Camaro, but still gives you a very good idea of what you might be getting into - NP440/MY6 Swap Info | NastyZ28.com
post #3 of 3 (permalink) Old 03-15-2019, 08:47 PM
11th Indian's Avatar
Quoted: 26 Post(s)
I am installing a Tremec 5 speed, I was told by the vendor (SilverStar) the the 68 to 72 only may6 need a slight dimple to install. Now the 66 to 67 is another story....
11th Indian is offline
OD Transmission Nicholas 1964-1974 Tempest, Lemans & GTO General Discussion 5 10-10-2018 09:11 PM
67 GTO Aftermarket RA, GV OD and ID Q's 42867Goat 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 9 05-09-2011 02:55 PM
64 GTO Automatic To 4 Speed Conversion javadoc 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 03-06-2011 10:02 PM
4 speed conversion muggsy 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 3 04-01-2008 02:53 PM
