Need a 10 bolt axle shaft - Pontiac GTO Forum
post #1 of 14 (permalink) Old 04-11-2012, 07:23 PM Thread Starter
FlambeauHO's Avatar
Quoted: 8 Post(s)
Need a 10 bolt axle, mine was damaged according to the shop doing my rearend.
Its a 28 spline regular Pontiac 10 bolt shaft. Anyone got one they can ship me?
FlambeauHO is offline
post #2 of 14 (permalink) Old 04-11-2012, 08:13 PM
Quoted: 16 Post(s)
Does Yukon axles have one? I've used them in the past and thier stuff is stronger than OEM.
post #3 of 14 (permalink) Old 04-11-2012, 08:31 PM Thread Starter
FlambeauHO's Avatar
Quoted: 8 Post(s)
I'm looking for a CHEAP used one, not concerned with strength, car is pretty stock.
post #4 of 14 (permalink) Old 04-11-2012, 09:29 PM
Hi, What year housing ? 64-67 are the same, but in 68-72 the housing and axles increased in length 1/2 inch per side.
JustAl is offline
post #5 of 14 (permalink) Old 04-11-2012, 09:32 PM Thread Starter
FlambeauHO's Avatar
Quoted: 8 Post(s)
Good call, its a 68 Thanks!
post #6 of 14 (permalink) Old 04-11-2012, 10:40 PM
I might have one from my original 69 10-bolt. Holler back if you want me to check for it.
post #7 of 14 (permalink) Old 04-11-2012, 11:51 PM Thread Starter
FlambeauHO's Avatar
Quoted: 8 Post(s)
Yeah, if you would part with it for a deal, I'm over budget a load on the rear end lol
post #8 of 14 (permalink) Old 04-12-2012, 10:28 PM
I'm pretty sure I've got them, but if they're where I think they are it's going to take some digging and I won't be able to get to them until I get the Beast put back together and running so I can move it. I've got the head back, waiting on a new set of valve stem seals which will either arrive tomorrow afternoon or early next week.
Don't let me forget...
How much do you think the axle is worth?
post #9 of 14 (permalink) Old 04-13-2012, 01:04 PM
68GTO4004Spd's Avatar
Ames sells new ones for $189 each, so do the math.
68GTO4004Spd is offline
post #10 of 14 (permalink) Old 04-13-2012, 01:07 PM
Quoted: 119 Post(s)
I paid $35 for one about 20 years ago for my '65 at a wrecking yard. The last one I bought 10 years ago from The Goat Farm was $175, but I had to have it. Also, all due respect JustAl, the '64 and '65 axles are the same, and the '66 up are longer by 1/2" or so. The one inch wider rear end was a '66 model year introduction. The '69 2.56 rear end assembly I swapped in to my '67 GTO is identical in every way dimensionally to the original rear end....one inch wider than the '65!
GTO Axle shaft insertion Hi Po GTO 1964-1974 Tempest, Lemans & GTO General Discussion 3 05-18-2010 02:56 PM
Is the 10 Bolt 8.2 BOP Carrier the same as Chevy 10 Bolt? mighty454 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 6 04-21-2010 04:30 PM
Broken Axle Shaft thull97 Drive train, suspension, alignment and brakes. 3 11-14-2009 01:11 PM
10 Bolt Versus 12 Bolt Rear Axle take5 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 10 09-28-2009 04:45 PM
cam shaft kit dallas64 Engine Discussions 9 06-25-2008 01:09 PM
