Need Help Identify to 10 Bolt Rear End - Code DN ? - Pontiac GTO Forum
LinkBack Thread Tools
Old 09-12-2013, 10:17 PM Thread Starter
Hello,
I need some help to ID a 10 Bolt GM Rear end, that has code DN (Delta Nancy) on the Axle Housing left tube upper,
On the right side of the axle housing tube, has the number - 3142, and then another number that is 8780100.
Some one has this rear end for sale, and is telling me it is for a GM A-Body '68 - '72, That is is a Posi rear end and has 3:73 gears
I am restoring a '69 GTO. Just would like to know if it fits...
I know that '69 GTO takes a 10 bolt rear end, and is supposed to be either 3:90, or 4:33 geared.
This particular rear end has been all gone through, and I can get it for what I think is a good price, but I would like to make sure that I know what exactly it is before I buy it.
I can't seem to locate any info on this on the Internet, all the links take me no where I need to go.
Can anybody help me to ID this rear end ?
Appreciate if could help
Thanks,
Lfryklu
Lfryklu is offline
Old 09-13-2013, 01:12 PM
chuckha62's Avatar
Quoted: 18 Post(s)
Have you seen it? Can you go see it? There are several flavors of "10 bolts". You need to know if it is a BOP, or a Chevy, then you need to know if it's an 8.2 or 8.5 inch. do you have a pic of the diff cover you can post? Do you know the width (backing plate to backing plate)?
Also...think real hard about your rear end ratio... I thought 3.73 was ideal, until I had to live with it in the real world. If it were mine, I'd run somewhere in the 3.23 to 3.55 range and be a happy camper.
chuckha62 is offline
Old 09-13-2013, 05:11 PM
Quoted: 11 Post(s)
Originally Posted by Lfryklu View Post
Hello,
D N should have an arrow between and indicates the shift the axle was manufactured, Day or Night.
3142 may be the Julian date code which would be the 314th day of 1972 or 1982 or 1992,
If indeed it is a 3:73:1 it would be a chevy rear end, Pontiac didn't use 3.73:1
If it is from a Chevy A-body it should fit.
In 72 Pontiac offered the GTO with the 3.08:1, 3.23:1, 3.55:1 and 3.90:1 in the 10 bolt, the 3.07:1, 3.31:1, 3.55:1, 3.90:1 and the 4.33:1 was offered in the 12 bolt which was standard with the 455 engine.
The axle gear code for Pontiac should be stamped on the left axle tube. Also this axle may be the 8.5 corporate axle which is also available in 3.73:1.
Can you post a picture of the pumpkin?
05GTO is offline
Old 09-14-2013, 04:06 PM
Quoted: 119 Post(s)
In '69, you could also get 2.56, 2.78, and 2.93 rear gears in the GTO. 2.93 was the standard ratio with automatic trans and AC. For an automatic car, a 3.08-3.23 ratio would be ideal for all around use, and for a stickshift car, a 3.23 would be my choice. Even 3.55's are punishing above 60mph sustained speeds. BTDT.
Old 09-20-2013, 12:36 PM
Not trying to hijack this thread, but I am interested in these rear end codes. I just pulled a 12-bolt posi rear end off a 1969 GTO, 4 spd manual. I do not know the specific gears, but the previous owner believed it was 2.93. How do I go about checking what the gears are? Where are these codes on the rear end?
mrvandermey is offline
Old 09-20-2013, 01:05 PM
68GTO4004Spd's Avatar
The two digit codes are on the right hand axle tube a few inches away from the pumpkin, they are about 3/8" tall, some are on the backing plate, but I can't remember if it's left or right. 69 GTO's didn't come with a 12 bolt, so that rear end could be just about anything. The original for a 69 would look like this.
68GTO4004Spd is offline
Old 09-20-2013, 10:59 PM
Agree on the ratio. I'm running 3.50's in my 69 (it's a Moser 9-inch) and at 70 mph the engine is crowding 3300 rpm.
3.90's and 4.33's were way overkill in nearly everything except for Ram Air IV cars that were mostly raced.
Old 09-21-2013, 11:32 PM
dan woodland's Avatar
Quoted: 34 Post(s)
I found this while searching the inter web today... hopefully this helps.
dan woodland is offline
Old 09-23-2013, 11:41 PM Thread Starter
Hi,
I found another 10" Posi rear end that has 3:08 gears.
I think you mentioned that you thought this would be pretty good for all around use.
Will be a 4 speed manual set up.
More thoughts ?
Thanks for your reply and comments
Lfryklu
Lfryklu is offline
10 or 12 bolt rear end? joesweeting 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 24 11-17-2012 08:00 PM
1970 GTO 12 bolt rear end HelpDeskGuy 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 13 03-03-2010 05:27 PM
72 LeMans 10 Bolt rear end questions HelpDeskGuy 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 5 04-07-2009 09:00 PM
12 Bolt Rear End? dbuchholtz Drive train, suspension, alignment and brakes. 2 01-30-2009 10:00 PM
