Need a new Rear end 1968 GTO - Pontiac GTO Forum
post #1 of 7 (permalink) Old 07-10-2017, 03:33 PM Thread Starter
Just toasted the rear end in my 1968 GTO. Would like to upgrade to a posi system. Anyone have a tip on what to buy and where? Planning on a 3.55 gear ratio.
blackheart is offline
post #2 of 7 (permalink) Old 07-12-2017, 10:04 AM Thread Starter
Auburn 3.55 posi is what I ended up with. No idea where mechanic is getting it.
post #3 of 7 (permalink) Old 07-13-2017, 09:57 AM
Quoted: 66 Post(s)
bigD is offline
post #4 of 7 (permalink) Old 07-15-2017, 05:58 AM
Depending on how much torque/power you're making (and of course the ever-present budget), you might consider solving the problem once and for all by swapping the whole assembly out for a 9". That's what I put under my '69, a Moser 9" with nodular center section, high spline count Moser axles, Wavetrac diff, and 3.50 gears - custom made with all the mounts to bolt right in. It wasn't cheap, but I'll never have to worry about breaking it - ever. I got mine from Spohn Engineering.
post #5 of 7 (permalink) Old 07-18-2017, 05:04 PM Thread Starter
Auburn 3.55 is in
Didn't want to lose any top end. Runs great and the entire repair including labor was under $2K. Just got her home.
post #6 of 7 (permalink) Old 07-18-2017, 07:54 PM
Quoted: 31 Post(s)
[QUOTE=blackheart;805737]Didn't want to lose any top end. Runs great and the entire repair including labor was under $2K. Just got her home.[/QUOTE
Glad to hear it worked out for you. I have a peg leg 2.93 in my 68 Gto that I want to make posi and having a ton of problems finding the fix. I love the gear ratio eith my turbo 400 but tire spin like crazy of the line into 2nd . I kept my rebuild close to stock on motor. Hoping I can find the same fix. Tough to do with 2.93 gears. Doug
dd68gto is offline
post #7 of 7 (permalink) Old 07-18-2017, 08:59 PM
Quoted: 66 Post(s)
"...I have a peg leg 2.93 in my 68 Gto that I want to make posi and having a ton of problems finding the fix..."
This Auburn 5420114 posi unit will work with 2.93 gears. Will that solve your problem ?
https://autoplicity.com/1196389-aubu...ngComNOFITMENT
https://www.justdifferentials.com/AG...5420114-hp.htm
https://www.summitracing.com/parts/a...RoC2usQAvD_BwE
bigD is offline
68 gto 2.93 rear end rbsmithjr 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 6 02-19-2015 12:01 AM
1968 GTO rear end question mrvandermey 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 28 10-20-2013 11:02 AM
64 GTO rear end khinton 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 2 03-24-2012 10:24 AM
1968 Lemans Rear end gears sknight751 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 4 02-22-2009 09:04 AM
67 GTO no rear end GTO_KID 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 4 05-10-2008 12:58 PM
