Pontiac Th350 housing hole? - Pontiac GTO Forum
post #1 of 1 (permalink) Old 09-08-2017, 10:48 PM Thread Starter
Took this tranny out of the '73 GTO. I assume its a 350? First tranny I've ever messed with so I don't know. No casting numbers on it anywhere. My mechanic said looks like a 350. Anyway, found some decent metal pieces in the pan so took it apart. Found the pictured hole just under where the shifter linkage hooks up to the valve. Is this supposed to be there? Or is the tranny case toast?
Planning on picking up a th400 tomorrow so this isn't needed for the GTO, just am wondering if I'll be able to use it for a trans am.
Thanks!
ID:	96530   Click image for larger version
ID:	96538   Click image for larger version
Tracto-man is offline
From TH350 to TH400 KowalskiCW 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 48 09-26-2017 11:26 AM
th350 to 2004r conversion ucaddoc 1964-1974 Tempest, Lemans & GTO General Discussion 1 12-31-2016 10:44 AM
hole in my bell housing RunninLeMans 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 04-27-2014 06:56 PM
th350 tranny swap 66tempest 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 09-17-2012 02:22 AM
why a pontiac th350 has green paint on it? danthepontiacman 1964-1974 Tempest, Lemans & GTO Paint Shop Discussions 6 03-06-2012 05:24 PM
