posi question - Pontiac GTO Forum
post #1 of 3 (permalink) Old 02-27-2016, 11:39 AM Thread Starter
posi question
Kinda new at the rear-end dept. please bare with me.
Will BOP 8.2 posi unit from a '67 gto fit a '64 buick skylark ?
Also will the 8.2 posi unit fit into a non posi 8.2 housing ?
pony462 is offline
post #2 of 3 (permalink) Old 02-28-2016, 10:42 AM
'64-67 Buick cast 8.2 housings accept the '64-69 Pontiac 8.2 carrier and the '70-72 Pontiac 8.2 carrier (just have to use matching ring and pinion).
The early Buick ('64-67) 8.2 10 bolt cast center housings are of a single rib casting design in the pinion area and lack a LOT of pinion support. Considering building off the early Buick 8.2 housing, and the build is going into a cruiser/driver, one should be fine. on the other hand, trying to throw 400 ft/lbs of torque at the early 8.2 Buick rear in a car that can hook, asking for trouble...better to go with a much stronger rear. Olds engineers figured this out for '65 with their manual trans 442's, the early 442's 400 engines just making too much torque for the Buick cast housings.
post #3 of 3 (permalink) Old 02-28-2016, 12:23 PM Thread Starter
Thank you so much, just checking before I sell this unit.
pony462 is offline
Posi Pontiacpurebrred 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 18 08-15-2011 03:34 PM
Posi issue/question xconcepts 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 03-23-2011 02:06 PM
question about posi differentials xcmac26 1964-1974 Tempest, Lemans & GTO General Discussion 11 12-21-2009 06:00 PM
'70 LeMans posi rear question bobj_70 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 2 10-23-2009 08:55 PM
69 GTO 10 bolt non-posi convert to 12 bolt posi AzStateFan 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 0 09-12-2009 05:34 PM
