Posi-traction Conversion 8.2 - Pontiac GTO Forum
post #1 of 2 (permalink) Old 01-03-2019, 07:17 PM Thread Starter
Roqetman's Avatar
Quoted: 16 Post(s)
Happy New Year Everyone! My ‘65/389 has open 8.2” rear end with 3.08 gear, th400 transmission. I’d like to change it over to a posi-traction but I’m at a loss to know which brand or type unit to use. I’m happy with the 3.08 gear but it seems the posi’s for the 8.2 require 3.31 or lower gear, like a 3.36. I mostly cruise around town and highways but wouldn’t mind seeing what it would do in the 1/8 or 1/4 mile occasionally. Also, I’m running 235-70R15 on the rear, 28” OD which is a fairly tall tire. So I’d like some sound advice as to whether the 8.2 is worth converting to posi or should I go with a 8.5” or 12 bolt and... what brand posi unit is the most bang for the buck, reliable, durable, i.e. Yukon, Richmond, Detroit Locker, etc? Any advice would be greatly appreciated. Thank you!
Roqetman is offline
post #2 of 2 (permalink) Old 01-04-2019, 07:54 PM
Posi-Traction conversion
according to my restoration book there could have been a 3.08,3.23,3.36,or3.55 with an automatic but only 3.08 or3.23 if it had air . Safe-T-Track codes were 3.08-ZE,3,23-ZF,3.36-ZG,3.55-ZH .
I have an 8.2inch 65 Safe-T-Track with 3.55 gears . It has an Eaton unit that I was told is very good,Richmond gears- some say a little noisy- others say not if it is set up right. You might check with Pete at Ames. On the codes if you change the Y to w that is for single track.
Datold1 is offline
posi traction Chris-Austria 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 04-03-2013 04:38 PM
posi traction Chris-Austria 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 07-12-2011 12:41 PM
69 GTO 10 bolt non-posi convert to 12 bolt posi AzStateFan 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 0 09-12-2009 04:34 PM
Traction control, still no traction :-) tummen 2004-2006 GTO General Discussion 14 08-22-2008 12:25 PM
Traction control VS no Traction control GOATTEE Racing and Kill Forum 18 12-11-2006 02:55 PM
