Rear axel id - Pontiac GTO Forum
post #1 of 5 (permalink) Old 05-02-2012, 07:35 PM Thread Starter
66goatframeoff's Avatar
Rear axel id
Bought a 66 LeMans 4 door parts car suprised to find a 10 bold posi under it but still can't find the letter codes without tearing it apart how can I tell the gear ratio ? 9783393 c166 only thing I can find.
66goatframeoff is offline
post #2 of 5 (permalink) Old 05-02-2012, 07:54 PM
68GTO4004Spd's Avatar
You could spin the pinion one rev and count how many revs the left wheel makes. 3 1/2 times is roughly 3:55. Or you could take the pumpkin cover off and find the ratio stamped on the ring gear. In the pic 39 divided by 11 is 3:55 gear. Sorry site too slow for the pic to load, the stamp will be the first 4 numbers 39-11 GM 6 70 1
68GTO4004Spd is offline
post #3 of 5 (permalink) Old 05-06-2012, 07:49 PM Thread Starter
found ring gear stamp 14114 gm2 66e is it a 411 ? the math does not work out ?know its eaton 66 .thanx for the help.
post #4 of 5 (permalink) Old 05-06-2012, 09:06 PM
Quoted: 11 Post(s)
It may be a 2.93, (41 divided by 14)
05GTO is online now
post #5 of 5 (permalink) Old 05-08-2012, 12:53 PM
spin the pinion and count the rotations, that will tell you if it 411 or 293 for sure
Hard to see rear of goat through inside rear view mirror common right?.... pctek 2004-2006 GTO General Discussion 8 11-22-2010 08:59 PM
rear axel revup47 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 2 05-02-2010 12:09 PM
?- looking for new rear end gears and rear suspension whytedude422 Service, Maintenance and Technical Discussion 3 03-31-2010 04:11 AM
