Rear axle ID 65 GTO - Pontiac GTO Forum
post #1 of 4 (permalink) Old 07-25-2013, 07:43 PM Thread Starter
Rear axle ID 65 GTO
I searched and read threads and still need help with my differential. My 65 has a 3.08 on PHS and an E only stamped just below the brake line clip on passenger side. I rotated the drive shaft in neutral and approximately 3.08 turns or approx 28 degrees past 3 full rotations of drive shaft equal 1 rotation of axle on both wheels with wheels off the ground, so I am pretty sure the diff is 3.08. My confusion comes when I look at the codes on differential decoders. it says the following
Differential Ratio 3.08
Std. Axle Code D
Std. Axle Sticker Code WE
Safe-T-Track Sticker Code YE
My question is: is the axle correctly marked with an E short for WE and therefore a 3.08?
yoke is offline
post #2 of 4 (permalink) Old 07-26-2013, 09:49 AM
68greengoat's Avatar
All axle codes where stamped with 2 letters except in '64 which were one. An "E" code for '64 was 3.36 which would be just shy of 3.5 turns. Maybe check the date code cast on the pumpkin, ex d224. Last digit is the year.
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline
post #3 of 4 (permalink) Old 07-26-2013, 12:22 PM Thread Starter
Thank you 68greengoat!
I did not check date code. it is F115 which matches my data plate and engine and all the rest. So since my test indicated 3.08, I went back to the axle code stamp with a wire wheel and worked down through paint and primer and there is a faint "w" there in front of the "E", so WE, 3.08 for 65. All is good with my new 65!
Thanks for steering me in the right direction.
yoke is offline
post #4 of 4 (permalink) Old 07-26-2013, 10:39 PM
Yep, those axle codes were lightly stamped and easily filled up with corrosion, grime etc.... Glad to hear it's a '65!
SOLD.....
462ci, 4spd
64 gto rear axle housing bushings 23plumpt 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 1 06-17-2010 09:09 PM
67 gto rear axle swap LTGOAT 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 1 10-20-2009 11:51 AM
2006 GTO Rear Axle Replaced GTO8 Drive train, suspension, alignment and brakes. 4 02-21-2006 09:38 AM
GTO rear axle Redline Service, Maintenance and Technical Discussion 5 08-16-2004 12:42 PM
