Rear Axle Replacement - Pontiac GTO Forum
post #1 of 4 (permalink) Old 06-23-2012, 01:15 AM Thread Starter
Logchain's Avatar
I just pulled my rear axle shafts on my 66 to have the bearings replaced and apparently they are worn out and no good. Guy at the machine shop said I would need to find replacements for both. Where is a good place to get some new ones?
Logchain is offline
post #2 of 4 (permalink) Old 06-23-2012, 01:29 AM
I found mine on Amazon. Go to jdrace.com to get the proper numbers that go with your car.
orelog is offline
post #3 of 4 (permalink) Old 06-23-2012, 07:57 PM
you can speedi-sleeve them as well
pontiac is offline
post #4 of 4 (permalink) Old 06-24-2012, 01:47 PM
455carl's Avatar
Lots on E-bay "we" get them in Canada at Car Quest or NAPA stores (normally same day) Try Pep Boys Murrays in US
1972 Lemans Sport L78 4 speed 1 of 16 Cdn. built
455carl is offline
what rear axle is this? shadetreegto 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 11 06-18-2012 10:01 PM
64 Axle Bearing Replacement Al T 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 18 05-10-2012 05:57 PM
Cv axle replacement, where to buy?? VenomGTO Drive train, suspension, alignment and brakes. 8 12-12-2010 09:51 PM
Rear Axle Replacement DaveH 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 2 12-18-2007 09:20 AM
GTO rear axle Redline Service, Maintenance and Technical Discussion 5 08-16-2004 12:42 PM
