rear differential ID - Pontiac GTO Forum
post #1 of 8 (permalink) Old 08-01-2015, 11:44 AM Thread Starter
Hi. I'm a newbie to this forum and I'm sure this type of question has been asked a thousand times, but I'm going to do it again.... I've got a 10 bolt posi B-O-P that I'd like to find out what it is out of. The only numbers discernible is the casting number on the bottom right ear of the housing. The number (I think) is 9782977. Can this tell me anything?
Thanks for the help.
mcyphert is offline
post #2 of 8 (permalink) Old 08-01-2015, 02:20 PM
Did you Google it?
GotTogO is offline
post #3 of 8 (permalink) Old 08-01-2015, 10:23 PM
I just chunked a bare gray iron Pontiac 8.2 housing with the "977" casting. The housing came out of a '66 Sprint 6 LeMans and was rust pocked, or I'd have kept it in one of the racks.
post #4 of 8 (permalink) Old 08-03-2015, 09:21 PM Thread Starter
Originally Posted by GotTogO View Post
Did you Google it?
Google wasn't any help....
mcyphert is offline
post #5 of 8 (permalink) Old 08-03-2015, 09:37 PM
It's always worth a shot.
GotTogO is offline
post #6 of 8 (permalink) Old 08-04-2015, 10:38 AM
deanhickey's Avatar
Quoted: 38 Post(s)
What year is the axel? In 1968 the ID number was moved to the left hand axel tube. there may still be a sticker on the lefthand rear brake drum. there was also stamping machine breakdown in 67 where the stamp was moved to top of the left hand axel tube. Hope this helps and good luck. i would recommend getting a copy of gto restoration guide by Paul Zazarine andChuck Roberts. That is where i was able to get this information.
deanhickey is offline
post #7 of 8 (permalink) Old 08-04-2015, 01:56 PM
The gray iron housing 9792977 was built with axle tubes and is either late '66 model use, or '67 model use. This particular center housing casting number was even used on housings for lower performance '67 Firebirds.
With the stamped assembly codes being tough to read, the easist way to identify which model year application is to look at the coil spring perches.
-Is the perch flat with a hole in the center, and take a stamped steel "ear" shaped piece to bolt the coil spring down, if so, with that casting number, late '66 usage.
-OR does the top of the coil spring perch flare up 1/2", with a locator ring being a part of the perch? If so, the rear was used in a '67 or extremely early '68 Pontiac, or possibly, a '67 Buick A-body.
post #8 of 8 (permalink) Old 08-08-2015, 10:02 AM Thread Starter
Thanks guys. This will definitely give me something to go on.
mcyphert is offline
Rear differential gen. ?s IMCauley Drive train, suspension, alignment and brakes. 8 01-06-2011 09:15 PM
Rear differential part number VettenGoat 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 1 06-16-2010 05:17 PM
harrop rear Differential cover? alptbird Drive train, suspension, alignment and brakes. 0 07-10-2006 11:46 PM
