rear end - Pontiac GTO Forum
post #1 of 7 (permalink) Old 03-15-2012, 04:43 PM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
rear end
While following wifey home from the shop, where we got the posi and axle bearings done, i noticed the 'pumpkin' seems to be "shaking" up and down.
I though all that would now be cured with the new axle (the old one was worn in half! by a seized bearing.......
Guessing it's the rear shocks (never been changed)
How much trouble is relpacing them?
thanks as always
Tk
Topkat is offline
post #2 of 7 (permalink) Old 03-15-2012, 05:50 PM
Sounds like a tire balance problem to me....
Eric Animal is offline
post #3 of 7 (permalink) Old 03-18-2012, 12:47 PM
Quoted: 119 Post(s)
Take it back to the shop and say that it's shaking. See what they do. I agree, if it's pogo-sticking on a smooth road, probably tire imbalance. Shocks are a half hour job...super simple.
post #4 of 7 (permalink) Old 03-20-2012, 12:22 PM Thread Starter
Topkat's Avatar
actually the pass. rear wheel was wobbling......
Topkat is offline
post #5 of 7 (permalink) Old 03-20-2012, 01:19 PM
Was it bent or left loose????
post #6 of 7 (permalink) Old 03-20-2012, 02:26 PM Thread Starter
Topkat's Avatar
it's on there tight.............must be bent.
Topkat is offline
post #7 of 7 (permalink) Old 03-20-2012, 05:45 PM
Quoted: 119 Post(s)
Bent axle flanges are really, really common with these cars. One curb hit will bend the axle flange. Remove the wheel and check the flange for run-out. It could just be a bent rim, but personally, it always seems to be an axle
Hard to see rear of goat through inside rear view mirror common right?.... pctek 2004-2006 GTO General Discussion 8 11-22-2010 08:59 PM
?- looking for new rear end gears and rear suspension whytedude422 Service, Maintenance and Technical Discussion 3 03-31-2010 04:11 AM
