Rear End Fit ? '67 into a '69 GTO ?? - Pontiac GTO Forum
post #1 of 5 (permalink) Old 09-24-2013, 09:31 AM Thread Starter
Hi Guys,
Found a Posi rear end with 3:08 gears from a 1967 GTO.
Been hearing from some of you guys that 3:08 is a pretty good all around gear ratio to go with.
Have a 4 Speed set up to match.
Question is: Will a '67 GTO rear end fit into a '69 GTO ?
What are any differences ?
Been told '68 - '72, but found this one... a '67
Appreciate the advice & help.
Lfryklu
Lfryklu is offline
post #2 of 5 (permalink) Old 09-24-2013, 07:05 PM
Quoted: 119 Post(s)
It'll bolt right in. I installed a '69 GTO rear end in my '67 GTO, and it's an exact match. No difference at all except the casting numbers. Go for it. You'll love the 3.08's in a street car if you ever drive over 50 mph.
post #3 of 5 (permalink) Old 09-24-2013, 07:08 PM
Quoted: 23 Post(s)
i believe the 69' would be around a half inch wider overall, otherwise they are the same but that just means you can get a little wider tire in there now.
Instg8ter is offline
post #4 of 5 (permalink) Old 09-24-2013, 11:48 PM
Direct fit just like the others said. The overall width is 1 inch narrower, but all attach points are the same.
JustAl is offline
post #5 of 5 (permalink) Old 09-25-2013, 01:09 PM
Quoted: 119 Post(s)
My '67 and my '69 rear ends measure exactly the same. No difference. The '64-'66 units were 1 full inch narrower.
64 GTO rear end khinton 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 2 03-24-2012 11:24 AM
will 69' 12 bolt chevelle rear end fit 66' tempest Instg8ter 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 13 12-31-2010 03:57 AM
1970 gto rear axle fit a in a 1967 lemans?? bnichols04 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 12 08-05-2010 03:30 PM
Will a 69 bumper fit on a 70 front end? scrapmaster 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 0 02-10-2009 05:10 AM
67 GTO no rear end GTO_KID 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 4 05-10-2008 01:58 PM
