rear end ride height - Pontiac GTO Forum
post #1 of 4 (permalink) Old 09-19-2017, 07:27 AM Thread Starter
My 70 Judge sits way too high in the rear end. it is just over 1" too high, measuring at the prescribed location on the rocker.s What is the BEST way to lower this since i have the conventional coil spring rear end?
truetriplex is offline
post #2 of 4 (permalink) Old 09-25-2017, 06:43 AM Thread Starter
suggestions please!
post #3 of 4 (permalink) Old 09-25-2017, 12:29 PM
clevelandpartsguy's Avatar
Obvious things you probably thought of, trying to think of why it may be sitting high, 15" wheels w 70 series tires? I think the 1969's came with air shocks, if you have them you might try lowering the air pressure. Do you have all stock Pontiac (or BOP) end?
clevelandpartsguy is offline
post #4 of 4 (permalink) Old 09-25-2017, 03:19 PM
Are you comparing ride heights or a '70 with Y96 Firm ride option? All '70 & 71 Judges came with Y96 (slightly taller stiffer springs as well as differently valved spiral shocks).
IF the rear height is taller than than Y96 specs with stock size G70-14's, my bet is the rear springs were replaced earlier with Moogs or other generic replacements.
1970 gto rear ride height qls1221*2016 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 5 01-15-2015 02:47 PM
Ride height Getyourgoat 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 1 10-28-2014 07:18 PM
'04 ride height question HalfWayOutTheDoor 2004-2006 GTO General Discussion 1 12-31-2010 05:08 AM
66 gto ride height dakuhns 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 10 07-15-2010 07:58 AM
