Rear ends - Pontiac GTO Forum
post #1 of 11 (permalink) Old 05-28-2014, 11:59 AM Thread Starter
Rear ends
Is the 67 Pontiac GTO rear end the same as a GM (ie Chevelle)?
John
hyfye is offline
post #2 of 11 (permalink) Old 05-28-2014, 03:21 PM
Quoted: 119 Post(s)
No. The Chevelle was a weaker, c-clipped rear end. You'd want one out of another Pontiac A body, or a Buick or Olds.
post #3 of 11 (permalink) Old 05-29-2014, 10:09 AM Thread Starter
Thanks I was looking to see if the lower control arms were the same
John
hyfye is offline
post #4 of 11 (permalink) Old 05-29-2014, 12:37 PM
Quoted: 11 Post(s)
You can indeed use a 10 or 12 bolt Chevelle (a-body) rear end in your 67 GTO, you may have to adjust the length of your drive shaft. The control arms should bolt in place.
05GTO is offline
post #5 of 11 (permalink) Old 05-30-2014, 10:16 AM
Quoted: 119 Post(s)
Yeah, the lower control arms are the same....from what I've run into, anyway.
post #6 of 11 (permalink) Old 05-30-2014, 05:32 PM
rickm's Avatar
Quoted: 5 Post(s)
a 12 bolt in a gto requires a chevelle driveshaft. the u joints are not the same size.
rickm is offline
post #7 of 11 (permalink) Old 05-31-2014, 05:44 PM
Quoted: 16 Post(s)
They do make "conversion" U-joints that will work with you existing driveshaft.
post #8 of 11 (permalink) Old 06-01-2014, 10:41 PM
maktope's Avatar
When i put the 12bolt in all i had to do was measure the yoke off the old one and order a matching one. went in easy didnt have to change a thing.
maktope is offline
post #9 of 11 (permalink) Old 06-02-2014, 05:34 PM
rickm's Avatar
Quoted: 5 Post(s)
in '79 when I put a 12 bolt in my '64, the most simple n cheap solution was to go to the local junkyard n buy a complete driveshaft from a manual trans. chevelle for $25.00. lol. miss those days !
rickm is offline
post #10 of 11 (permalink) Old 06-02-2014, 06:27 PM
Quoted: 119 Post(s)
I do, too. $75 Muncies and $50 posi rear ends. No more, that's for sure!
refresh my memory on rear ends 68gtohawk8369 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 7 10-16-2011 11:08 AM
Rear Tie Rod ends firebird Drive train, suspension, alignment and brakes. 9 08-09-2011 08:29 PM
04-05 rear ends PEARL JAM 2004-2006 GTO General Discussion 3 04-09-2007 06:15 AM
Durability of rear ends chad1140 Racing and Kill Forum 2 04-09-2005 03:49 PM
How tough are the rear ends in these Goats?? tiresmoker Service, Maintenance and Technical Discussion 4 02-25-2005 06:50 PM
