rear wheel play - Pontiac GTO Forum
post #1 of 3 (permalink) Old 01-07-2016, 10:40 AM Thread Starter
rear wheel play
How much back lash or play is acceptable between the rear wheel and the drive shaft.
Thanks for any help in advance,
66
sixtysix is offline
post #2 of 3 (permalink) Old 01-07-2016, 12:25 PM
Quoted: 119 Post(s)
Very little. I'd say less than a quarter of an inch. Hopefully Pinionhead will chime in...he's the expert on this. If you have 1/2" or more 'slop', you are looking at some repair or adjustment.
post #3 of 3 (permalink) Old 01-07-2016, 05:58 PM
Quoted: 119 Post(s)
On second thought, when rotating a rear wheel and looking at the driveshaft, about 1-2 inches of wheel movement before the driveshaft turns is pretty much normal.
whats the 2 rubber plugs at the back rear wheel, wheel well?.... pctek 2004-2006 GTO General Discussion 2 10-15-2018 09:00 AM
rear wheel queak irishdude Wheels and tires 1 06-24-2011 11:35 PM
Rear Wheel Alignment Vettekid1992 Drive train, suspension, alignment and brakes. 1 06-04-2010 10:21 PM
How much rear wheel HP kanibal Engine Discussions 3 01-05-2007 01:23 AM
Rear wheel HP StangStalker Service, Maintenance and Technical Discussion 1 08-27-2005 10:47 PM
