Rebuilding the differential - Pontiac GTO Forum
post #1 of 3 (permalink) Old 06-25-2016, 09:23 PM Thread Starter
I have a number matching 1966 GTO that I have had since 1980, I have had the engine rebuilt (thanks to Butlers Performance), rebuilt the transmission myself, but have never touched the differential, any suggestions on rebuilding or replacing?
Guinness is offline
post #2 of 3 (permalink) Old 06-27-2016, 10:01 AM
If you drive the vehicle moderately with near stock size tires and wheels, would consider starting with replacing the wheel bearings, if they have not been replaced. Sealed axle bearings are a ticking time bomb, so any times, they seize and chew up the axles. If the original rear is behind a relatively stock drivetrain, the posi still hooks up, and the rear end grease has been changed several times over the course of the GTO's life, the rear may not need much. I can get much more detailed, if you need. Have found the limits of the gray iron Pontiac 8.2 rears, as well as the limits of other performance era rears.
post #3 of 3 (permalink) Old 06-28-2016, 09:26 PM Thread Starter
Great suggestion, I have stock tires and spin the wheels every now and then, but nothing serious. I had the back wheel bearing go out many years ago, quite scary, but should probably get them replaced. I have never done any maintenance to the differential, so I am guessing I need to change the oil/grease? If you have a pointer to how to do this I would really appreciate it.
Guinness is offline
Recommendation for Engine Rebuilding 67PLUMMIST 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 8 04-03-2015 08:15 AM
Preping Parts for rebuilding/restoring. Josh.AZ.GTO 1964-1974 Tempest, Lemans & GTO General Discussion 12 08-15-2011 11:48 AM
Cylinder Head Rebuilding Help Needed g-mack 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 2 03-03-2009 07:29 AM
rebuilding thc301 Engine Discussions 5 06-21-2007 10:37 PM
Need Help Rebuilding! Split1atom 2004-2006 GTO General Discussion 3 12-10-2004 06:22 AM
