Rebuilding Muncie - Pontiac GTO Forum
post #1 of 1 (permalink) Old 03-25-2019, 09:13 AM Thread Starter
Quoted: 153 Post(s)
Rebuilding Muncie
I need to install a new clutch and figured this would be a good time to fix a few transmission leaks and replace syncros. I was hoping to send off to Paul G. (5 speeds), but he is too backlogged. Do any of you have someone you'd recommend or is this something I should attempt to do myself (I've never done a transmission rebuild). Thanks
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is online now
Rebuilding '65 389 3x2's motor (Suggestions) sbutler 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 7 12-23-2009 08:36 PM
Cylinder Head Rebuilding Help Needed g-mack 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 2 03-03-2009 06:29 AM
after rebuilding top of engine, lower now leaks gotgoat 2004-2006 GTO General Discussion 7 01-12-2009 06:36 AM
rebuilding thc301 Engine Discussions 5 06-21-2007 09:37 PM
Need Help Rebuilding! Split1atom 2004-2006 GTO General Discussion 3 12-10-2004 05:22 AM
