Replacing the original automatic transmission with a manual one - Pontiac GTO Forum
post #1 of 4 (permalink) Old 12-23-2012, 10:35 PM Thread Starter
I'm thinking about swapping out the original two speed automatic transmission in my 65 GTO with a manual one. What are some recommendations on which one to get and where to get the conversion parts?
patty1 is offline
post #2 of 4 (permalink) Old 12-24-2012, 08:57 AM
Quoted: 16 Post(s)
If you want a four speed I would recommend a Muncie M-20. Still pretty plentiful and you should be able to procure a servicable gearbox in the $300 - $600 range. I would also recommend getting a factory service manual or the excellent GTO restoration guide by Paul Zazarine for diagrams of all the components.
Aside from the gearbox you will need - A flywheel (factory are cast iron which is fine for stock but you might want to consider steel if your budget allows), a bellhousing ( Pontiac, Olds, and Buick used a specific one, different from Chevrolet. Stock is cast aluminum, aftermarket is steel), clutch and pressure plate (lots of aftermarket support here), throw out bearing, and you'll need a clutch pedal and linkage as well as a different brake pedal (Manual are narrower).
Sticks are a lot more fun to drive if installed right.
If you are interested in an overdrive, I highly recommend the Tremec five speed. That is all dependant on your driving needs, your rear gear and your budget.
post #3 of 4 (permalink) Old 12-24-2012, 11:57 AM
Quoted: 119 Post(s)
What ALKY said. M 20 is better than an M-21 due to it's lower first gear ratio. In CA, prices are $600 for a beater trans to $1300 for a done one. I've seen nice ones for about $800. The $$$$ is going to be in the pedals, belcrank (Z-bar), frame tab (labor) console (if you want one) and labor in general. This is not a cheap conversion, but it will change the feel of the car entirely. Another option is to pull the 2 speed auto and simply bolt in a TH350 auto trans. This alone will make the car feel like it picked up 100 horsepower. This is a far more cost effective option. (the 4-speed will also make it feel like a real musclecar too!!) Good luck........
post #4 of 4 (permalink) Old 12-26-2012, 03:48 AM Thread Starter
Thank you both for the info!
patty1 is offline
Automatic to Manual Transmission conversion. JESchulte 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 8 08-02-2016 04:38 PM
67 GTO with leaking transmission; automatic jimmy328 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 6 04-27-2012 11:42 PM
Automatic Vs. Manual Transmission drosene Service, Maintenance and Technical Discussion 17 09-11-2007 05:06 PM
Automatic or Manual Tranmission? I Stall Automatics The Lounge 0 10-30-2005 08:54 PM
2004 GTO..6 speed manual or Automatic? IH2ton6cyl Service, Maintenance and Technical Discussion 5 10-21-2004 11:10 AM
