Ring Gear Number Question - Pontiac GTO Forum
post #1 of 3 (permalink) Old 05-03-2017, 08:28 AM Thread Starter
Went to change the rear in my 70 GTO to 3:73 and found these numbers on the present ring gear: 3A42 GM LC 251
Can anyone tell me what these numbers signify? (I bought the rear some time ago as a Pontiac 3:08 12 bolt rear.) I'll count the teeth and figure out the present ratio. But I've not seen these numbers before. Hoping to be able to use the same carrier. Thanks for your help.
Jjkra is offline
post #2 of 3 (permalink) Old 05-03-2017, 11:01 AM
The 12 bolt gear set is most likely a GM service (parts) gear set from much later. I've ran into similar inscribed numbers on NOS 3.31 12 bolt gear sets which I've set-up.
On your 12 bolt, am assuming the '70 is a factory 455 car, I'm keep track of original housing stamped dates & codes. If the lower right hand webbing of the center housing does not have an alphanumeric date code, would be interested in what your axle tube is stamped. Thanks!
post #3 of 3 (permalink) Old 05-12-2017, 03:46 PM Thread Starter
Thanks, but this is not an original 455-car. The 400 was gone when I bought it. Rear is not original either. Sorry, wish I could help you further.
Jared
Jjkra is offline
Ring and Pinion Gear for GTO alanmay0 1964-1974 Tempest, Lemans & GTO General Discussion 5 09-30-2017 10:34 AM
Is the 67 GTO ring gear a non C clip?? alanmay0 1964-1974 Tempest, Lemans & GTO General Discussion 4 12-03-2016 02:51 PM
'65 GTO Rear gear ring and pinion change. tigervette 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 1 04-06-2015 03:12 PM
What is the best ring gear for mpg and performance for a 66 GTO with a 4 speed RSWHITE 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 7 12-06-2014 01:12 PM
