shifter needed - Pontiac GTO Forum
post #1 of 10 (permalink) Old 11-19-2015, 09:22 PM Thread Starter
Reb
Reb's Avatar
shifter needed
One of the few "GTO" parts my LeMans was not equipped with when I bought it was the His & Hers Shifter. Have the complete console, but there was a B&M inside.
Would like to set the car up with correct shifter, but my budget just will not permit purchase of a new one.
Anyone have a used assembly in good condition? I'm ok with replacing the bezel on top.
Thanks very much.
Oh, here's a recent picture of the car, fresh out of the paint booth.
Name:	GTO final paint.jpg
Reb is offline
post #2 of 10 (permalink) Old 11-20-2015, 11:27 AM
I copied this thread and posted it in the parts wanted section, good luck with your search.
post #3 of 10 (permalink) Old 11-21-2015, 05:11 PM
Lemans guy's Avatar
Quoted: 79 Post(s)
I looked at that on my 66 lemans, but you had to change the whole console..
So is that a 67 with a th400 trans? And it had a hurst dual gate?
My 66 has a B&M dual gate hides right in original console with minor changes...
Looks almost stock and works great...
Lemans guy is offline
post #4 of 10 (permalink) Old 12-07-2015, 07:18 PM
Red..my favorite color
88redconvert is offline
post #5 of 10 (permalink) Old 12-09-2015, 07:25 AM Thread Starter
Reb
Reb's Avatar
Car is in fact an original column-shift automatic, to which a B&M floor shifter had been adapted. An oem console had also been installed, albeit without the oem dual-gate bezel. I am fine with an aftermarket (less expensive) shifter. Was just hoping to use original-style his n' hers shift gate. Possible?
Note, we have installed modern OD transmission.
Also, current B&M shifter mechanism has no capacity for lateral deflection, so not adaptable to a "gated" shift bezel.
I will look online for B&M Dual-Gate. Thank you for the information.
Reb is offline
post #6 of 10 (permalink) Old 12-09-2015, 03:56 PM
Quoted: 23 Post(s)
If you get the standard shifter bezel the B&M fits right in the slot with a little shimming up and operates just like the his part of the his and hers. Even used -up dual gates are hard to find under 500.00, good luck.
Instg8ter is offline
post #7 of 10 (permalink) Old 12-10-2015, 10:28 AM
have 6 or 7 factory Hurst Dualgates, most are fairly complete. Irishmic is in line for the first '67. Am looking for parts tubs they are in, problem is nearly everything is palletized, awaiting our move.
Doing a swap with a OD transmission, you might ck with Shiftworks to see if they have the correct steel gate and lucite selector lens to convert a factory Dualgates shifter to OD, that maybe a hang up.
post #8 of 10 (permalink) Old 12-12-2015, 10:24 PM
Reb, You have a PM
pony462 is offline
post #9 of 10 (permalink) Old 12-13-2015, 06:32 AM Thread Starter
Reb
Reb's Avatar
This is all good information. Thank you!
Since my car is a hodge-podge of LeMans-to-GTO conversion, I'm not totally hung up on absolute correctness. I'm very happy just to have the console. GTO-style His&Hers shifter assembly would be nice, but budget is always a factor.
Existing B&M shifter is perfectly functional. I'm considering reusing it, but if so just want to find a way to fill gap in console opening with something other than H&H bezel.
Reb is offline
post #10 of 10 (permalink) Old 01-08-2016, 10:15 AM
Quoted: 23 Post(s)
I had to make some shims from tubing to raise and move the mounting point of the shifter to center the complete throw to the Pontiac console bezel and the rubber dust cover from the B&M can be trimmed and siliconed to the back of the original Pontiac bezel plate to close the slot.....should be pictures on my build link at the bottom.
Brian
will a 1968 lemans floor shifter cable work on a 1968 GTO dual gate shifter par4n1 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 03-09-2013 08:50 PM
shifter base needed 6.Goat Drive train, suspension, alignment and brakes. 1 08-13-2012 09:20 PM
B&M Shifter - modification needed. LS2FAST Service, Maintenance and Technical Discussion 5 11-08-2005 09:14 PM
