Side movement on floor mounted auto? - Pontiac GTO Forum
post #1 of 1 (permalink) Old 08-03-2016, 12:58 PM Thread Starter
KowalskiCW's Avatar
Quoted: 38 Post(s)
So I bought this 69 lemans 350/350 combo a month or so ago and notice the auto shifter on the floor has the ability to push to the right. I'm not sure why it does this. I tried a couple times using like a gated shifter but haven't had success. Is it just a slop or is it supposed to do something?
Also moving the shifter from gear to gear is very stiff and slow. Is there a way to loosen the movement of the shifter or is it supposed to be like that as well?
Thanks!
69 Lemans
KowalskiCW is offline
Airbags with side mounted air lines doww301 Drive train, suspension, alignment and brakes. 2 03-12-2013 10:30 AM
Water on driver side floor board. joesweeting 1964-1974 Tempest, Lemans & GTO General Discussion 16 12-09-2012 08:40 PM
70 GTO auto on floor shifter sweet70gto 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 04-10-2012 07:43 AM
1966: convert from column to floor shift (auto) torpedo51 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 7 03-27-2011 04:57 PM
TH400 no movement kjk990 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 10 10-06-2010 07:45 PM
