SPEEDOMETER GEAR-- 64 Lemans GTO - Pontiac GTO Forum
post #1 of 1 (permalink) Old 09-20-2015, 10:05 PM Thread Starter
khinton's Avatar
How do you change the speedometer gear on a 64 with Muncie 4 speed. Everything is in the way! The cross member, all the shifting rods; one that can't be removed. Is it necessary to remove the cross member? Is there a tool that helps with this?
khinton is offline
Speedometer Drive Gear and Driven GEAR timmyg 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 05-05-2012 04:48 PM
Muncie speedometer gear SPCMarty 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 13 04-08-2012 08:03 PM
Speedometer gear gtoearl 1964-1974 Tempest, Lemans & GTO General Discussion 11 12-22-2009 09:00 AM
Speedometer Gear Question jpdog357 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 07-16-2007 10:28 PM
need help getting the right speedometer cable gear ergo Service, Maintenance and Technical Discussion 2 05-07-2006 10:04 AM
