Th400 maintenance - Pontiac GTO Forum
 6Likes
  • 4 Post By BLK69JUDGE
  • 2 Post By john23
post #1 of 3 (permalink) Old 09-30-2018, 04:24 PM Thread Starter
deanhickey's Avatar
Quoted: 38 Post(s)
Th400 maintenance
I have my 68 th400 out of my car while awaiting the engine to be redone. I am looking for recommendations on any maintenance that should be done wile I have it out and am able to work on it>
deanhickey is offline
post #2 of 3 (permalink) Old 09-30-2018, 07:15 PM
BLK69JUDGE's Avatar
Quoted: 67 Post(s)
a few things come to mind
have you driven the transmision b4 ?
what color is the fluid ?
filter change with a new 1 piece rubber pan gasket
replace front and rear seals
pull speedo and install new o rings and check gear shaft for wear.. JUST buy a new gear
was your speedo off before ?
gear change may be needed
drain the torque converter
new tranny mount
buy a ne w torque converter cover if u dont have one
lube the speedo cable
new dip stick tube O ring
new u joints
just off the top
Scott
BLK69JUDGE is online now
post #3 of 3 (permalink) Old 10-08-2018, 10:45 AM
new tranny mount
new u joints
just off the top
Scott
Scott,
you've covered it pretty well. coupla things. now would be the time to do any dressing or modifications on the female fittings for the fluid lines in and out on the passenger side of the trans.
flush the trans cooler in the radiator. strongly consider installing an aftermarket trans cooler.
consider installing a drain plug in the trans pan. it makes future maintenance much easier with a clean way to draw down the trans fluid
consider installing a shift kit
and of course, the obvious, if the trans has lots of miles and/or abuse on it, now would be the time for a rebuild.
1968gto421 and deanhickey like this.
john23 is offline
Tips on any maintenance I would need to do for long term storage millertime034 Service, Maintenance and Technical Discussion 6 01-01-2009 07:19 PM
Battery Maintenance OHIO06 Service, Maintenance and Technical Discussion 1 12-06-2008 12:00 PM
Dealer maintenance? kevracer Service, Maintenance and Technical Discussion 7 10-07-2006 09:27 PM
Small Maintenance Tip Wing_Nut Service, Maintenance and Technical Discussion 7 05-29-2006 03:07 PM
Is GTO high maintenance? h777 2004-2006 GTO General Discussion 17 06-28-2005 06:07 PM
