TH400 Transmission????? please help.... - Pontiac GTO Forum
post #1 of 3 (permalink) Old 07-22-2012, 09:46 AM Thread Starter
I just rebuilt my 69 GTO. It has a 400 engine and has a automatic TH400 transmission. I just put the engine back in, put the torque converter and transmission in the car and then broke the engine in yesterday. the car ran great and sounds amazing. i finished cleaning up all the wiring and then put the brake booster on the car. i was planning on driving the car last night and it started up, and when i went to put it in gear, it would not go into any gear. the transmission was recently rebuilt and worked fine before i pulled the car apart.
is there anything i can troubleshoot, like the way i put it back together or linkage, anything that would cause the car not to go into any gear on the shifter. anything helps.
thanks
Eshack80 is offline
post #2 of 3 (permalink) Old 07-22-2012, 09:53 AM
First thought is the shift cable. Have you checked your gearshift cable and linkage? Did it pull out at the bracket attached to the tranny? Did you replace this cable or reattach it correctly when the trans was reinstalled?
post #3 of 3 (permalink) Old 07-22-2012, 10:06 AM Thread Starter
I am going in the garage right now to lift the car up. I am going to have my wife shift it from neutral to drive and see whats happens underneath the car. I will let you know shortly what happens.
Eshack80 is offline
TH400 Problems BearGFR 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 18 01-26-2012 03:56 PM
TH400 trans help gotyorgoat 1964-1974 Tempest, Lemans & GTO General Discussion 7 01-08-2012 01:38 PM
200 4R vs TH400 kilkm68 1964-1974 Tempest, Lemans & GTO General Discussion 10 11-08-2011 09:06 PM
Th400 dhinnah 1964-1974 Tempest, Lemans & GTO General Discussion 3 10-24-2010 06:43 PM
What to ask for my 455 and th400? 67goatman455 1964-1974 Tempest, Lemans & GTO General Discussion 8 08-09-2009 06:51 PM
