Is there a bushing that belongs here? - Pontiac GTO Forum
 1Likes
  • 1 Post By BLK69JUDGE
post #1 of 3 (permalink) Old 07-17-2019, 02:22 PM Thread Starter
Quoted: 17 Post(s)
Guys,
I'm checking to see if anyone can tell me if there is supposed to be a bushing here on the this pivot arm where the transmission shifter cable linkage is connected to the column linkage for the shifter. It seems that this connection is very sloppy and would benefit from a bushing or spacer that would tighten up this connection. The shaft currently just sits in the hole in the bracket and seems very sloppy to me. Can someone help me with this?
Mike
ID:	120231   Click image for larger version
ID:	120233   Click image for larger version
ID:	120235   Click image for larger version
70conv is offline
post #2 of 3 (permalink) Old 07-17-2019, 03:54 PM
BLK69JUDGE's Avatar
Quoted: 74 Post(s)
plastic bushing cone shaped in the hole
a soiled spring ... around that rod arm your showing
and a washer to hold the spring against the bushing
I should have an extra set of originals I could ship today ... if your in a hurry...
or they are available aftermarket also
Scott
2o6 465 9165
do you have the correct hair pin clips on both ends ??
integrity6987 likes this.
BLK69JUDGE is online now
post #3 of 3 (permalink) Old 07-18-2019, 11:41 AM
yes of course. Ames should also have them
God, Country, Cars
gmjunkie is offline
