Are these common frame cracks? - Pontiac GTO Forum
post #1 of 5 (permalink) Old 12-16-2012, 09:12 PM Thread Starter
leeklm's Avatar
I was hoping to avoid the restoration thread, but here I am...
While cleaning up my front clip, I noticed some cobbled up welding on the frame rail, along with a crack, just in back of rear mount of the lower control arm (see red mark in pic). Both sides look the same, and had a previous repair as evidence by the chicken-s**t weld.
I plan to weld a patch over these areas to strengthen it up, but was curious if it is common for the A-body frame to crack here?
Also, I had some rust-through on the outside of frame rail where the steering box bolts on (collects garbage on the inside and rots). After cutting the bad stuff out, I am going to weld in a patch.
For these types of repairs, what gauge of steel do you guys like to use? I assume it does not need to be too heavy so you can form as needed...
Thanks!
Name:	frame crack.JPG
leeklm is offline
post #2 of 5 (permalink) Old 12-16-2012, 10:34 PM
Leek, I will check with my body man on Wednesday....he restores a lot of A body cars.....Eric
Eric Animal is offline
post #3 of 5 (permalink) Old 12-20-2012, 06:23 PM Thread Starter
leeklm's Avatar
just bumping this up to the top... Curious if this is a common issue. I will be fixing regardless. Maybe the PO had a torque monster motor he was racing and stressed the frame? I certainly did not purchase the car with a torque monster motor...
leeklm is offline
post #4 of 5 (permalink) Old 12-21-2012, 10:03 PM
They are not too common, unless there is a bunch of rot in the chassis. Then cracks will start to form in that place. Usually, rust out is common in CONVERTABLE car chassis, as they are closed rail, and water lays inside.
I would cut the cracks out, plate, weld and grind/body work for strength and correct look. Eric
post #5 of 5 (permalink) Old 12-24-2012, 06:55 PM Thread Starter
leeklm's Avatar
As I mentioned in another post, the front end had some damage once upon a time. Looks like it was on the frame rack, which would explain the cracks where they are located. It is about the only "crumple zone" these old cars had! The frame is pretty solid, except around the steering gear bolts where it collected 47 years of debri and moisture on the inside. A little patch & weld will make it as good as new.
I remember banging up a few old "bomber cars" at the track, and this is where they would all fold up at any hit above 20mph!
leeklm is offline
Factory wheel discoloration and hairline cracks Aspired Wheels and tires 4 04-03-2012 11:40 AM
Common Window Issue? doubleb0924 Service, Maintenance and Technical Discussion 10 11-30-2011 03:52 PM
common grounding issues? Chaz 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 12-02-2008 07:23 PM
Clunking a common problem? KinskiGTO Drive train, suspension, alignment and brakes. 13 08-28-2007 11:13 AM
