Think I screwed up something - Pontiac GTO Forum
post #1 of 11 (permalink) Old 11-05-2016, 06:36 PM Thread Starter
GtoWayner68's Avatar
Coming home from a short cruise I was not able to avoid a pot hole, thankful that I didn't bust a tire I definitely did something. As now I have a bad vibration and passing car the other day said my wheel was wobbling. Don't notice it till 55mph + so had no idea. Looking at wheel there's no bends or leaks. So I'm thinking I bent my Axle or axles. But everything looks straight by it sitting.... Idk.
How do I figured this out for sure before dropping the $ and how do I go about identifying what axle and bearings I need?
GtoWayner68 is offline
post #2 of 11 (permalink) Old 11-05-2016, 06:54 PM
BLK69JUDGE's Avatar
Quoted: 74 Post(s)
Sounds like its time for a floor jack under the front control arm , and get the tire off the ground and spin it and shake it ....
PUT GLOVES ON !!!
A belt or belts probably broke in the tire and the wire belts could be exposed when you spin and wiggle the tire ...
Scott
or
a local tire store ... but I wouldnt drive it any more....
possibilities are endless ....
time for a professional inspection... BOTH sides
BLK69JUDGE is online now
post #3 of 11 (permalink) Old 11-05-2016, 07:42 PM Thread Starter
It's in the rear. Fronts are golden.
Sorry should've been more specific.
post #4 of 11 (permalink) Old 11-05-2016, 07:56 PM
Quoted: 404 Post(s)
As noted, the steel belt can break or get damaged within the tire. I have had the same thing happen on my Toyota after hitting a really nice pot hole filled with water that looked like nothing to be concerned about.
Also bent a rim on the same car on a construction pot hole - they filled it in with dirt prior to paving, but it rained over the weekend, the dirt settled, and I nailed it in the 6 AM darkness with the rim edge and bent it good enough to cause the tire to leak air at the bead.
Both instances cause vibration. I would have both the tire inspected & the rim checked out for straightness, both of which your local tire shop can do for you. Have them also check the lower control arm/bushings on that side as well,which should be fine, but have them check it anyway for piece of mind.
post #5 of 11 (permalink) Old 11-05-2016, 10:14 PM Thread Starter
Will do. I need to get an alignment anyway.
post #6 of 11 (permalink) Old 11-05-2016, 11:41 PM Thread Starter
If not and it is rear axles how does one get the right stuff the first time. Lol
post #7 of 11 (permalink) Old 11-06-2016, 11:15 AM
1968gto421's Avatar
Quoted: 72 Post(s)
If it is a rear axle, I'd get in touch with member PinionHead as he is the forum expert on rear end things....a fountain of knowledge. He cold tell you how to determine if it is bent and what to do. He also has a stash of rear end parts and can fix you up with what you need. He has fixed member Dan Woodland up with parts and Dan's been real pleased. I don't have a dog in this fight but do know how hard it is anymore to find good used parts for these cars since we've lost so many boneyards to developers.
1968gto421 is offline
post #8 of 11 (permalink) Old 11-08-2016, 09:39 AM
PH is the expert on rears. Sounds to me like you may have a bent axle.
post #9 of 11 (permalink) Old 11-10-2016, 03:57 PM Thread Starter
Thanks guys. I will give him a holler. Appreciate it.
post #10 of 11 (permalink) Old 11-18-2016, 01:59 PM Thread Starter
Ok. Had a chance to dig into the rear end today. Axle bearings are both shot. And I'm assuming that with them being bad for so long I'll just do rear axles as well. Now can anyone point me in the right direction... Casting on rear end is 979217 or 77 or 11 (hard to see the last 2 digits) and is a 10 bolt. So what axles do I need and bearings?
passenger window screwed up dustyminpin 2004-2006 GTO General Discussion 6 06-09-2010 05:43 PM
Possible screwed half shafts? goatfan2004 Drive train, suspension, alignment and brakes. 6 11-29-2009 06:05 PM
Contractor screwed me for $6000. Pass this on... tbyrne The Lounge 21 06-25-2007 04:56 PM
I'm So Screwed Groucho The Lounge 17 04-06-2007 09:07 PM
GTO Screwed Again b_a_betterperson The Lounge 10 07-26-2005 06:57 PM
