THM 350 question - Pontiac GTO Forum
post #1 of 1 (permalink) Old 08-12-2017, 03:47 PM Thread Starter
Quoted: 9 Post(s)
THM 350 question
Good Afternoon All,
I'm getting some vibration in the driveline that changes at certain speeds. I replaced the U joints, but made no difference and inspected the tranny mount and that is good. I noticed that when I had the driveshaft out, the output shaft has quite a bit of play in it. is that normal? I believe that when the driveshaft is in place, the play would be less, but before I tear into it I would just like your advice. I understand there is a bushing in the tailshaft section. Could that need replacing?
Thanks,
Armand
ajluzi1957 is online now
Thm 400 id mbspeed 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 05-01-2013 09:15 AM
400/350 69 Engine Question funbooker 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 11 12-12-2012 06:26 PM
easy turbo 350 transmission question virginiavenom 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 2 06-25-2011 09:49 PM
leaky turbo 350 question 67lemans 1964-1974 Tempest, Lemans & GTO General Discussion 6 11-23-2009 09:54 PM
Question about the 350 H.O. Darren Service, Maintenance and Technical Discussion 3 12-19-2004 07:34 PM
