Torque converter bolt pattern? - Pontiac GTO Forum
post #1 of 3 (permalink) Old 07-15-2015, 10:18 AM Thread Starter
busaben's Avatar
Send a message via Yahoo to busaben
Good morning everyone, I have a simple question that I have a hard time finding the answer to. What is the bolt pattern spacing for the torque converter on a pontiac flywheel? I thought it was 10" between the three bolts, but I cannot confirm.
I am about to install a 200r4 trans and need to get the appropriate 27 spline converter.
Thanks for any help
busaben is offline
post #2 of 3 (permalink) Old 07-15-2015, 10:19 AM Thread Starter
busaben's Avatar
Current trans is a th350, forgot to mention that
busaben is offline
post #3 of 3 (permalink) Old 07-15-2015, 05:56 PM
Quoted: 4 Post(s)
Many Pontiac flexplates have a dual bolt pattern, so that you can use either the small or large GM pattern. The small is 10.75" & the large is 11.5". If yours has only one pattern, you can buy a new dual pattern flexplate fairly cheap.
http://www.summitracing.com/parts/at...ily/pontiac-v8
http://www.autozone.com/1/products/1...r-fra-103.html
http://www.oreillyauto.com/site/c/de...3232&ppt=C0338
oldskool is offline
Bolt Pattern??? LS2~N~BLUE Wheels and tires 10 07-15-2019 08:42 AM
10.75 or 11.5 torque converter bolt pattern? swanwr 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 1 09-05-2012 04:01 PM
bolt pattern mikey gto 1964-1974 Tempest, Lemans & GTO General Discussion 1 07-30-2011 02:53 PM
Bolt Pattern JTYLER1604 Service, Maintenance and Technical Discussion 1 06-06-2005 01:38 PM
Bolt Pattern? BRIAN P. EWING Service, Maintenance and Technical Discussion 11 12-30-2004 08:54 AM
