Trans Cooler question - Pontiac GTO Forum
post #1 of 3 (permalink) Old 11-18-2017, 06:29 PM Thread Starter
Hi Guy's,
It's getting into summer here in Australia & the 100+ degree days are just around the corner & I'm looking to install a trans cooler to my 69 GTO before the heat really hits.
The question is do I bypass the radiator & remove the trans cooling from its job completely & just have the external cooler hooked up to the trans? or do I run both.. so have the hot fluid enter the Rad still & then exit the rad & enter the external cooler & then return to the trans or is that just overkill & pointless?
Dave
1969 Pontiac GTO
1972 Dodge Challenger Sixpack R/T Clone
1975 Ford XB Fairmont GS Coupe
1975 Ford XB Falcon 500 Coupe
4.2 Supercharged V8 RangeRover Sport
Daved_XB is offline
post #2 of 3 (permalink) Old 11-18-2017, 07:16 PM
Quoted: 106 Post(s)
Cooler should be installed inline on the inline to the radiator side pre cooling the fluid before it goes into the radiator.
Goat Roper is offline
post #3 of 3 (permalink) Old 11-19-2017, 08:39 AM
Quoted: 391 Post(s)
I have always used the trans coolers in place of the radiator and disconnected the lines from the radiator. In this way, trans fluid is not going through the radiator to either be heated up or put heat into the radiator. Never had a problem doing it this way.
05 GTO AT4 and trans cooler question R3V Service, Maintenance and Technical Discussion 2 01-18-2017 11:13 PM
Trans cooler lowpro192000 Drive train, suspension, alignment and brakes. 0 06-26-2011 10:37 PM
A4 trans cooler bridogr1 2004-2006 GTO General Discussion 1 06-26-2011 02:00 PM
Trans cooler lines teamwoody72 1964-1974 Tempest, Lemans & GTO General Discussion 6 05-03-2009 06:37 AM
Trans cooler question 04 Goatman Service, Maintenance and Technical Discussion 0 09-22-2007 03:21 PM
