Transmission Cross Brace - Pontiac GTO Forum
post #1 of 5 (permalink) Old 05-29-2015, 01:42 AM Thread Starter
Hi
Have any of you guys made your own transmission cross brace or would happen to have the critical dimensions or plans that you could share with me?
Looking to make something like this:
https://www.opgi.com/gto/1968/chassi...ounts/CH28439/
Hope someone on here can help
Scott
Molten is offline
post #2 of 5 (permalink) Old 05-29-2015, 09:43 AM
Quoted: 16 Post(s)
Hey Scott, I made my own trans crossmember out of tubular steel and made it a true bolt in rather than the factory "floating" crossmember. To bolt it in I welded in boxing plates on either side of the frame that are flush with the inside channel opening. On either side of the new crossmember I fabricated some simple plates that welded on each end to bolt to the boxing plates. The crossmember has a dip in the center with the transmission mount welded on it.
This unit from Speedway Motors looks pretty identical to what I fabbed (and would have probably saved me some time ) except I have 4 bolt flanges on the ends instead of 3.
Tubular Transmission Mount with 2 Inch Drop - Speedway Motors, America's Oldest Speed Shop
post #3 of 5 (permalink) Old 05-29-2015, 11:16 AM Thread Starter
Is there any dimensions published anywhere?
Molten is offline
post #4 of 5 (permalink) Old 05-29-2015, 01:54 PM
Quoted: 16 Post(s)
I wouldn't think you would attempt this if you couldn't read a tape measure.
My flanges looked like these - http://www.speedwaymotors.com/Bolt-I...Ends,8937.html
post #5 of 5 (permalink) Old 05-29-2015, 04:09 PM Thread Starter
I have the steel to make the one in my post.
If anyone else made one, I'd be glad of any advice.
The one at speedways does seem like a good cheap alternative though.
Molten is offline
transmission cross member tspring 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 1 03-11-2015 04:20 PM
Cross-country in 68 GTO old68goat 1964-1974 Tempest, Lemans & GTO General Discussion 9 06-07-2014 05:37 AM
Cross country cruise? youngGoat 2004-2006 GTO General Discussion 21 02-28-2011 06:19 PM
Auto Cross Gril Humbler05Tredm6 Exterior Discussions 6 11-13-2006 07:54 PM
