Transmission leak; what’s the best way to seal the pan? - Pontiac GTO Forum
post #1 of 5 (permalink) Old 05-28-2012, 02:14 PM Thread Starter
What’s the best way to seal the transmission pan?
Currently I have a rubber gasket that appears to be in good condition; however, I think I would prefer to use cork with non-hardening Permatex. Can’t find it locally. Good idea or no? I re-threaded one of the stripped holes in the aluminum housing, bought a new deeper pan with a drain plug, replaced the dip stick and regulator. I know there are other places for potential leak but this is a good start. Would pure silicone work?
Thanks in advanced for your suggestions.
jimmy328 is offline
post #2 of 5 (permalink) Old 05-28-2012, 04:09 PM
Quoted: 119 Post(s)
No sealer needed on the pan gasket. Cork is fine, so is the regular gasket material composition of the gaskets that come in the filter kits. Pan rails must be straight and not bowed in by over-tightening. I sometimes use grease to hold the gasket in place, but usually just stick about 4 bolts thru the pan and gasket to hold it. The secret is to NOT over-tighten the pan bolts. Just snug.
post #3 of 5 (permalink) Old 05-28-2012, 05:19 PM
chuckha62's Avatar
Quoted: 18 Post(s)
Originally Posted by geeteeohguy View Post
... The secret is to NOT over-tighten the pan bolts. Just snug.
This ^^^^^^
but, also make sure the pan rails are absolutely flat around the holes before you put the pan back in place.
chuckha62 is offline
post #4 of 5 (permalink) Old 05-28-2012, 05:55 PM Thread Starter
Will do. This could have been my ignorance in the past; that is, over tightening, hence the reason two bolts stripped the holes in the aluminum casing. Yes, rails flush and tighten in a cris-cross pattern. I believe the torque specs are 11 or 12 foot pound.
Thanks GeeTEE and Chuck.
jimmy328 is offline
post #5 of 5 (permalink) Old 06-06-2012, 01:36 AM
torque are inch pounds, not ft pounds.
pontiac is offline
Is a rear main seal leak a big deal jtwoods4 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 02-17-2012 01:35 PM
1966 GTO Main Bearing Seal Leak Question take5 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 18 01-31-2010 05:06 PM
68 Gto Rear Main Seal Leak khinton 1964-1974 Tempest, Lemans & GTO General Discussion 16 03-14-2009 07:01 PM
Diff. pinion seal leak @ 11.5K cat1055man Drive train, suspension, alignment and brakes. 3 12-13-2007 06:27 AM
Transmission Leak Jerry Libes 2004-2006 GTO General Discussion 0 05-18-2005 09:41 AM
