Transmission leak continues despite repairs - Pontiac GTO Forum
post #1 of 2 (permalink) Old 06-02-2012, 08:43 AM Thread Starter
I’ve replace the pan (higher capacity), the dipstick tube, and modulator trying to rule out potential leaks. Got it all back together, drove about 15 minutes to heat up the fluid, put it back in the garage and turned off the motor. I can see fluid dripping from what appears to be the modulator (replaced with O-ring) at about 20 drops per minute.
Any ideas of how to repair this? A thicker o-ring? Is there some form of a gasket maker?
Thanks,
Jim
jimmy328 is offline
post #2 of 2 (permalink) Old 06-03-2012, 10:51 PM
waltcoleman's Avatar
What's the transmission? Any chance you could post pics? I spent several weekends chasing transmission leaks...trans oil pump, pan gasket, kickdown switch o-ring, speedo gear assembly, so I know what you're going through.
waltcoleman is offline
The battle of the trans fluid leak continues waltcoleman 1964-1974 Tempest, Lemans & GTO General Discussion 0 04-01-2012 08:10 PM
Transmission leak NEEDLEZ 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 42 10-15-2011 04:25 PM
Transmission leak TxSoldier6.0 Drive train, suspension, alignment and brakes. 3 06-02-2011 12:45 AM
68 Transmission Leak - Thoughts? cgseaman 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 5 09-16-2010 11:26 PM
Transmission Leak Jerry Libes 2004-2006 GTO General Discussion 0 05-18-2005 09:41 AM
