Is transmission original?? - Pontiac GTO Forum
post #1 of 5 (permalink) Old 08-19-2013, 02:33 AM Thread Starter
What's up guys, how's it going? I was wondering if anyone knows what numbers to look at to tell if the transmission in my 66 GTO is original or not. I have an M21 4 speed. I had it reuilt not too long ago and in the process I found that it is a date correct 1966 transmission but that still doesn't tell me for sure if it's the original tranny that came in my car out of the factory. I know there is numbers on the transmission somewhere (not sure exactly where). Is that number supposed to match any of the numbers on the rest of the car like the metal tag on the driver side of the firewall under the hood or the tag on the driver side door post?
doc21127 is offline
post #2 of 5 (permalink) Old 08-19-2013, 09:33 AM
On my 66. the vin: number of car is stamped on the top front edge of tranny.
mcguiremcd is offline
post #3 of 5 (permalink) Old 08-20-2013, 10:57 AM
Sir, I believe you should be looking on the left side near the top front edge of the transmission. That number should match the serial number you find on the left side pillar. Matt
Matthew is offline
post #4 of 5 (permalink) Old 08-20-2013, 08:39 PM Thread Starter
If its towards the top will I be able to see it with the tranny bolted in place or should I have looked for it when I had it off for the rebuild?
doc21127 is offline
post #5 of 5 (permalink) Old 08-21-2013, 09:45 AM
Sir, you should be able to see it. As for your question about looking when the transmission was out... no challenge in doing it that way. Matt
Matthew is offline
Original Owner!!! BearGFR 1964-1974 Tempest, Lemans & GTO General Discussion 23 02-23-2013 09:57 AM
Original 67 jack ROGTO67 1964-1974 Tempest, Lemans & GTO General Discussion 11 02-22-2013 03:35 PM
Replacing the original automatic transmission with a manual one patty1 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 3 12-26-2012 03:48 AM
where's my original motor masterblaster 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 2 08-08-2012 11:12 PM
Original Color or Something Else Chips 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 9 11-27-2011 03:50 PM
