u-joint to diff - Pontiac GTO Forum
post #1 of 4 (permalink) Old 08-12-2018, 10:50 AM Thread Starter
u-joint to diff
How does the u-joint bolt onto the pinion yoke on a 67 Lemans/GTO? is it with straps or u-bolt type?
I've had my 67 for two years and just now have reached the drivetrain.
The car came with a driveshaft, about 61" center to center. This seems a bit long for a th400. Seems to me that it may be off of a lemans 326. I could be wrong. Any info is appreciated.
pmihelis is offline
post #2 of 4 (permalink) Old 08-12-2018, 11:12 AM
BLK69JUDGE's Avatar
Quoted: 67 Post(s)
Hello
that does seem long.... correct length is 60" for the 2 speed cars center to center on u joints...
did you measure overall length ?
also
u bolts on our 10 bolts w nuts and lock washers
t 400 trannys are 5/8 of an inch approx longer than the early muncies thru 70
so
the t400 driveline is 60 minus 5/8" = 59 3/8 " center to center for the 67 GTO...
I have a nice 67 GTO drive line for the t 400 and correct original u bolts and hardware if needed
Scott
206-4six5-9165 Lacey WA
BLK69JUDGE is online now
post #3 of 4 (permalink) Old 08-12-2018, 07:52 PM Thread Starter
Thanks for the reply. I looked today and didn't see threads inside the pinion yoke so it looks like u-bolts. It does actually measure 60", I'm just retarded. My retardation lead me to get the wrong u-joints tho.
Once I get the shaft in, then the interior and rear brakes and she'll be road worthy!
pmihelis is offline
post #4 of 4 (permalink) Old 08-12-2018, 09:14 PM
BLK69JUDGE's Avatar
Quoted: 67 Post(s)
and
youre driveline is still the wrong length
Scott
Transmission mounts and universal joint parts ?? AlaGreyGoat Drive train, suspension, alignment and brakes. 4 08-24-2009 11:54 AM
Rag Joint/Pitman arm dastoria 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 02-09-2009 08:21 AM
65 GTO Power Steering Rag Joint Question WideTrack 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 0 07-23-2008 08:09 PM
Ragged out steering joint VettenGoat 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 2 06-30-2008 05:29 PM
04 diff/05 diff banshee 2004-2006 GTO General Discussion 8 08-23-2007 08:26 PM
