U-Joint size - Pontiac GTO Forum
post #1 of 7 (permalink) Old 03-02-2016, 09:25 PM Thread Starter
U-Joint size
I just bought a fresh 12 bolt for the 65. My question is my driveshaft and old axle are out of a 442 with 3R ujoint. New axle is 1310 and old was Saginaw 3r. Can anyone tell me id the Saginaw 3r is the same as the spicer 1344. I am trying to find a conversion u-joint from 3r to 1310 and I can find 1310 to 1344. Dimensions are very close. Any help is appreciated. I would like to find something strong and not just a store brand. Thanks
mjc707 is offline
post #2 of 7 (permalink) Old 03-02-2016, 10:23 PM
GTO's (and Pontiac LeMans) used the 3R ujoints from '64-73. 442's always used the 3R. Most Chevrolet 12 bolt rears accepted the common Spicer 1310 .
The conversion ujoint you need is a NEAPCO 3-1330, Precision 372 will also work. In building differentials I always build with the correct pinion flange, so don't have to deal with adaptor ujoints.
post #3 of 7 (permalink) Old 03-03-2016, 06:31 AM Thread Starter
Thanks .The Precision 372 is one of the ones that says 1310 to 1344. Thats what I wanted to verify. I can get the moog 372 locally just wanted to make sure it would fit. I am not r running crazy HP but I wanted to make sure I got a strong ujoint. Any issues with strength either of these part numbers you gave me?
mjc707 is offline
post #4 of 7 (permalink) Old 03-03-2016, 11:26 AM
Quoted: 4 Post(s)
Built several bracket racers, all with a 12-bolt rear. Used one of the conversion joints in every one. Never broke a joint or had any joint or DS problems. And this was using big slicks. Don't think you'd ever break one, on hard street tires.
The Neapco 3-3130 looks to be only $11.99 + tax @ Advance.
http://shop.advanceautoparts.com/p/n...Sr0aAovH8P8HAQ
O'Reilly shows a 372 for $8.99 + Tax.
http://www.oreillyauto.com/site/c/de...ngeSearch=true
The Precision 372 is about $17 shipped from Ebay.
http://www.ebay.com/itm/PRECISION-37...3D281136360920
http://www.ebay.com/itm/Precision-37...-/281136360920
oldskool is offline
post #5 of 7 (permalink) Old 03-03-2016, 04:00 PM Thread Starter
I appreciate the info Thanks
mjc707 is offline
post #6 of 7 (permalink) Old 03-03-2016, 05:34 PM
rickm's Avatar
Quoted: 5 Post(s)
never heard of someone bustin a u-joint or a manufacturer making a crappy one.
rickm is offline
post #7 of 7 (permalink) Old 03-03-2016, 05:54 PM
Quoted: 4 Post(s)
Some of the guys over on the Pontiac Drag Racers Facebook page say they have broken joints, which in turn, caused a lot of other damage.
They tried to talk me into going with a shaft which uses the big 1350 joints. But, I just have a mild pump gas 455 footbraker bracket car. I don't need the big joints.
Then, somebody else said that if I was going to use the small 1310 joints, I should at least get the non-greasable kind. They say that the threaded hole and grease channels, weaken the joint. But, I've never broken a greasable joint before. And since I'm not using a trans-brake, I don't think I'll break one now.
http://www.wranglerforum.com/f210/u-...le-356026.html
"... or a manufacturer making a crappy one."
I've read that there are some inferior grade Chinese joints & slip yokes.
http://www.made-in-china.com/multi-s...Catalog/1.html
oldskool is offline
1969 Universal Joint funbooker Service, Maintenance and Technical Discussion 4 10-29-2013 11:03 AM
Rag joint ?? Rukee 1964-1974 Tempest, Lemans & GTO General Discussion 13 01-12-2012 06:00 PM
rag joint question danthepontiacman 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 5 10-10-2011 09:29 PM
ball joint lube Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 6 06-23-2011 12:15 PM
Ragged out steering joint VettenGoat 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 2 06-30-2008 05:29 PM
