Weird converter/crankshaft pilot bore size - Pontiac GTO Forum
post #1 of 3 (permalink) Old 07-12-2018, 03:23 PM Thread Starter
I have a 69 GTO w/ TH400, and for some reason the crankshaft pilot bore measures 1.685 rather than the standard 1.703. As far as I know the crankshaft is stock, but I'm the 3rd owner so who knows what went on in the past. The smaller pilot bore size in the crank is making it impossible for me to replace the torque converter as none of them have a pilot hub small enough to fit. So far no machine shop is willing to try turning down the pilot hub the .0021 I need to clear it and I haven't had much luck finding anyone else with a similar issue. I appreciate any suggestions. Thanks!
Mors is offline
post #2 of 3 (permalink) Old 07-12-2018, 10:11 PM
RMTZ67's Avatar
Quoted: 78 Post(s)
pilot bore
Am I missing something? I thought the crank pilot bore was for manual transmission. are you talking flywheel?
RMTZ67 is online now
post #3 of 3 (permalink) Old 07-12-2018, 10:19 PM Thread Starter
On the back of the torque converter there's a short pilot hub (the snout/nose) that goes through the flexplate and slides into the end of the crank.
Edit: I also found out today I can ship it to TCI and they'll take the nose down so that's likely the solution I'll go with.
Mors is offline
Square Bore Carb on Spread Bore Eddy Manifold Bensjammin66 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 2 09-04-2015 07:38 AM
pilot bearing size MotoNut 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 02-13-2013 06:16 AM
Anyone know the head gasket bore required for 389 Willshire 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 13 07-26-2011 11:29 AM
LSx bore machining Poncho Dan Engine Discussions 7 01-22-2010 10:56 AM
Should I bore my 2004 GTO? Dan81 Engine Discussions 7 02-23-2009 04:57 PM
