What are the size of the factory backing plates? - Pontiac GTO Forum
post #1 of 2 (permalink) Old 04-15-2019, 11:46 AM Thread Starter
Guys,
I'm about to order a new 12 bolt rear to replace the 10 bolt in my 70 GTO. I want to stay with the factory brake set up to minimize the installation hassle, with the e-brake and whatever. I'm looking for a new set of backing plates and the ones I have found seem to be for 9 1/2 brakes. Is that the factory brake set up? Planning on just transferring over all my brake components. Thanks for any help.
Mike
70conv is offline
post #2 of 2 (permalink) Old 04-15-2019, 05:11 PM
Quoted: 321 Post(s)
Originally Posted by 70conv View Post
Guys,
Mike
My opinion here as I am not an expert on this, but the 12-bolt and 10 bolt will be different. The Pontiac 10-bolt uses a plate with 4-bolts to hold the axle in. The Chevy 12-bolt uses C-clips to hold the axles in. I am not sure if you can simply swap backing plates as the axle tube ends may be different as well as axle tube size - but just assuming at this point.
Watch out for idiots backing up! oryfoxer7410 2004-2006 GTO General Discussion 13 01-23-2011 09:08 PM
knocking noise when backing up gto_rider Service, Maintenance and Technical Discussion 5 10-06-2009 08:04 AM
70 GTO backing plate sgav24 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 09-01-2009 03:54 PM
Thanks for not backing it VettenGoat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 03-14-2009 02:09 AM
